Using Cycles as a viewport renderer with single GPU causes extreme UI lag on Windows #56828
Closed
opened 2018-09-17 15:11:40 +02:00 by Ludvik Koutny · 6 comments
Contributor
Windows 10, GTX1080Ti, 399.24 drivers
Broken: Latest 2.79 Master, 2.8 - Sep 17 2018
Worked: probably never
On Windows 10, with single GPU, running Cycles as interactive viewport renderer results in severe UI lag as soon as scene reaches certain shading complexity. Using the very same single GPU setup to render a final frame (F12 key) results in no UI lag. Therefore Cycles GPU utilization is handled differently (worse) for viewport rendering.
1, Test on a Windows 10 machine with a single CUDA capable GPU
2, Open a scene of higher complexity which can render on the GPU (Classroom or Victor scene will do)
3, Set active viewport mode to rendered.
4, Increase preview Cycles samples to reasonable amount (128)
5, Perform an action to induce Cycles viewport update
6, Try to interact with UI while viewport renders
Result: Blender's UI lags heavily during rendered viewport update
Expected: Performance penalty for viewport GPU rendering should be same as for final frame GPU rendering - no UI lag.
**System Information** Windows 10, GTX1080Ti, 399.24 drivers **Blender Version** Broken: Latest 2.79 Master, 2.8 - Sep 17 2018 Worked: probably never **Short description of error** On Windows 10, with single GPU, running Cycles as interactive viewport renderer results in severe UI lag as soon as scene reaches certain shading complexity. Using the very same single GPU setup to render a final frame (F12 key) results in no UI lag. Therefore Cycles GPU utilization is handled differently (worse) for viewport rendering. **Exact steps for others to reproduce the error** 1, Test on a Windows 10 machine with a single CUDA capable GPU 2, Open a scene of higher complexity which can render on the GPU (Classroom or Victor scene will do) 3, Set active viewport mode to rendered. 4, Increase preview Cycles samples to reasonable amount (128) 5, Perform an action to induce Cycles viewport update 6, Try to interact with UI while viewport renders Result: Blender's UI lags heavily during rendered viewport update Expected: Performance penalty for viewport GPU rendering should be same as for final frame GPU rendering - no UI lag.
Author
Contributor
Added subscriber: @Rawalanche
Ludvik Koutny changed title from Using Cycles as a viewport rendered with single GPU causes extreme UI lag on Windows to Using Cycles as a viewport renderer with single GPU causes extreme UI lag on Windows 2018-09-17 15:11:56 +02:00
Added subscribers: @brecht, @mont29
Brecht Van Lommel was assigned by Bastien Montagne 2018-09-18 09:29:16 +02:00
I’d bet that’s more like known limitation than bug, but will let you decide her, @brecht.
Already discussed here: https://devtalk.blender.org/t/how-does-cycles-handle-gpu-thread-priority-and-can-it-be-changed/1059/7
Brecht Van Lommel removed their assignment 2020-01-18 14:26:40 +01:00
Brecht Van Lommel self-assigned this 2020-06-18 18:51:08 +02:00
Windows now supports compute preemption which should help with this problem.
Reference: blender/blender#56828
