Building on Windows: Case sensitivity folders issue
Open, Confirmed, LowPublic
Windows 10 Pro, v.1803 (build 17134.228)
Broken: rBa349527981 (blender 2.8 HEAD)
Windows supports case sensitive folders (yup, it is per folder) now. And Blender can´t build if either the lib or the source folders are case sensitive. It doesn´t find a range of libraries and files: Python3.7, RNA_blender_cpp.h, GL\glew.h, ...
The easy way to do it is by creating the root folder (where blender source and lib is stored) via Ubuntu on Windows, which is how I ran into the issue originally. This way the folder is automatically set as case sensitive.
Optionally you can create the folder and later change it with fsutil.exe file setCaseSensitiveInfo <path> enable.
If you want to do this recursively you will need powershell for that:
[string] $PathRoot = 'C:\src\blender_root'
@(Get-ChildItem -Path $PathRoot -Recurse -Directory | Select-Object -ExpandProperty 'FullName') | ForEach-Object {
cmd /c ('fsutil.exe file SetCaseSensitiveInfo "{0}" enable' -f ($_))
Reference Links
Related Objects
Dalai Felinto (dfelinto) triaged this task as Confirmed, Medium priority.
Assigning to platform maintainer @LazyDodo (LazyDodo) but I may tackle it myself in the far future.
I'm still on 7 so can't repro, i'll eventually will take peek here.
Brecht Van Lommel (brecht) lowered the priority of this task from Confirmed, Medium to Confirmed, Low.Mar 26 2019, 5:05 AM
