Compositor: Auto Render doesn't work #56875
Closed
opened 2018-09-22 06:17:37 +02:00 by Shinsuke Irie · 11 comments
Member
Ubuntu 18.04
Broken: 2.79-2.79b
Worked: 2.78c or earlier
Compositor that Auto Render is enabled doesn't re-render or composite even when changes on 3D edits happen.
Confirmed with both Blender Internal and Cycles.
auto_render_test.blend
  • Open auto_render_test.blend
  • On 3D viewport, edit something (e.g. Move default cube)
    and then nothing happens with v2.79 (or later)...
**System Information** Ubuntu 18.04 **Blender Version** Broken: 2.79-2.79b Worked: 2.78c or earlier **Short description of error** Compositor that Auto Render is enabled doesn't re-render or composite even when changes on 3D edits happen. Confirmed with both Blender Internal and Cycles. **Exact steps for others to reproduce the error** [auto_render_test.blend](https://archive.blender.org/developer/F4794270/auto_render_test.blend) - Open auto_render_test.blend - On 3D viewport, edit something (e.g. Move default cube) and then nothing happens with v2.79 (or later)...
Author
Member
Added subscriber: @IRIEShinsuke
Added subscriber: @sebastian_k
It does work when you are using the Defocus Node, using the Z-Buffer of the current scene. Could be that this is the only node that does actually trigger a render update, but then the Auto Render button would be quite misleading indeed.
Added subscriber: @mont29
Please follow our submission template and guidelines, also read these tips about bug reports, and make a complete, valid bug report, with required info, precise description of the issue (only ONE issue per report!), precise steps to reproduce it, small and simple .blend and/or other files to do so if needed, etc.
Please follow our [submission template and guidelines](https:*developer.blender.org/maniphest/task/edit/form/1/), also read [these tips about bug reports](https:*wiki.blender.org/wiki/Process/Bug_Reports), and make a complete, valid bug report, with required info, precise description of the issue (only ONE issue per report!), precise steps to reproduce it, **small and simple** .blend and/or other files to do so if needed, etc.
Confirmed, would guess something went wrong in the update notifiers…
Bisecting points to 4cf7fc3b3a as breaking commit. Not sure what went wrong there, that is rather large commit :/
Lukas Stockner was assigned by Bastien Montagne 2018-09-23 16:40:05 +02:00
Added subscriber: @LukasStockner
Tried undoing some changes done in snode_set_context() but no success so far. @LukasStockner this falls on your desk am afraid. ;)
Tried undoing some changes done in `snode_set_context()` but no success so far. @LukasStockner this falls on your desk am afraid. ;)
This issue was referenced by 24330f679e
This issue was referenced by 24330f679e39f83cbbe4b85625b08d933ff4a14e
Member
5 Participants
Reference: blender/blender#56875
