Keying set ID Block "Shader Nodetree" isn't saved when reopening Blend File #56882
2 Participants
Reference: blender/blender#56882
Windows 10 Pro
Geforce GTX980
Broken: 2.79 2018-09-20 22:15
Broken: 2.79 b
When K is pressed (or right click add to keying set) over an inputsocket of a node group, an id-block named "Shader Nodetree" and a datapath (for example: nodes["Emission"].inputs- [x].default_value) is added under the scene tab in the column "Active Keying set". When the blend file is saved after this and reopened, the path is still there but the id-block is empty and it's not possible to manualy input the value "Shader Nodetree" as am id-block again. So everytime I open the blendfile I have to delete and add again every item by pressing k. Otherwise no keyframes are added for the items with no id-block.
Added subscriber: @MarcZbinden
Added subscriber: @mont29
Please follow our submission template and guidelines, also read these tips about bug reports, and make a complete, valid bug report, with required info, precise description of the issue (only ONE issue per report!), precise steps to reproduce it, small and simple .blend and/or other files to do so if needed, etc.
The id-block of the keyingset path isn't saved if the id-block is "Shader nodetree"
It's also not possible to manualy input "Shader Nodetree" into id-block field. Clicking on the empty field instead opens a list of all nodegroups in the blend file if there are any.
Keyingset.blend
Ah OK, now I see… Issue is caused again by broken initial design nodes, the 'top level' node tree is not a real datablock, but some fake ID that is actually private data of its owner (a material, for shader nodes). This is breaking whole animation system, you have to manually edit those to use the material as ID, and add
node_tree.
to the beginning of the RNA path.You’ll have the same issue e.g. when trying to use a node's value as driver parameter. Unfortunately, there is no simple way to address those issues, so this is considered a known TODO/limitation of current code, not a bug. Thanks for the report anyway.
