Bsurfaces failure to set 'Cross' and 'Follow' parameters.
Windows 10 64-bit
renderer: 'GeForce 840M/PCIe/SSE2'
vendor: 'NVIDIA Corporation'
version: '4.6.0 NVIDIA 389.12'
Version: 2.79 (sub 4), branch: blender2.8, commit date: 2018-06-05 17:29, hash: 713027b, type: Release
with
Bsurfaces GPL Edition, 1.5.1, as shipped.
Having ctreated a Bsurface, any attempt to adjust the 'Cross' and 'Follow' values in the 'Bsurfaces add surface' panel results in the following error:
File "C:\Program Files\Blender Foundation\Blender\2.79\scripts\addons\mesh_bsurfaces.py", line 3085, in execute bpy.data.objects[self.main_object.name].select = True
ReferenceError: StructRNA of type Object has been removed
  1. Create mesh object to contain surface
  2. Create series of Bezier splines to be lofted, in a single curve object (The error is also occurring with Grease Pencil strokes attached to the mesh object)
  3. Select curve, then mesh.
  4. Put mesh into Edit Mode.
  5. In the only available Bsurfaces panel, hit 'Add Surface'
(The surface is created. So far, so good. Another panel becomes available: 'Bsurfaces add surface')
  1. Any attempt to change the 'Cross' or 'Follow' fields in the new panel results in the error.
The blender version you use is already quite old. Can you try if you can reproduce the same bug in a newer version?
https://builder.blender.org/download
Looks like the Bsurfaces addon has not been updated so far.
Hello Jacques, thanks very much for your attention..
Successfully reproduced:
Version:
2.79 (sub 6), branch: blender2.8, commit date: 2018-09-26 00:55, hash: 63658ae76dc, type: Release
Error:
  File "C:\Users\Robin\Documents\Blender\BUILDS\blender-2.79-63658ae76dc-win64\blender-2.79.0-git.63658ae76dc-windows64\2.79\scripts\addons\mesh_bsurfaces.py", line 3086, in execute
There's been some modification to mesh_bsurfaces.py? The error line number has nudged?
Before reporting, I confirmed the behavior with three members of Blender Stack Exchange .. unfortunately no detailed info on their versions, systems.
Bastien Montagne (mont29) triaged this task as Normal priority.
@Jacques Lucke (JacquesLucke) Eeeh… BSurface is a community add-on, better to let its author handle any fix/updates. ;)
@Eclectiel L (eclectiel) , summoning you here :)
Hello,
Does anyone know if there is any update or perhaps another way to manually change the number of "cross"? I keep getting 5 sets of lines which is unfortunately not great for what I currently need.
Thanks,
-MH
Brendon Murphy (meta-androcto) closed this task as Archived.
Archived. 2.8 updates should have solved this @Spivak Vladimir (cwolf3d) correct me if I'm wrong.
