Netrender: errno 32: Broken pipe #56938
Blender Cloud
Documentation
Eevee & Viewport
Import and Export
Rendering & Cycles
Add-ons (BF-Blender)
Add-ons (Community)
Reference: blender/blender-addons#56938
Fedora 28
2.79b, Python version 3.6.6
I am setting up the network renderer, but when I send tasks to the master, I get "[Errno 32] Broken pipe".
On the master, I see:
Set up a master and a slave, send a task from client to master.
My investigation
The problem seems to happen when the client tries to send the job files. This is done in line 338 of client.py, using the request() method of HTTPConnection. The argument is a file handle, no headers are specified. The documentation of this method says:
(see https://docs.python.org/3/library/http.client.html)
So, no content-length when using a file object. It is visible from the stack trace (length = int(self.headers['content-length'])) that the master expects the content-length to be set. This leads to the exception.
I have not yet tried whether explicitly setting the content length header solves the problem.
Added subscriber: @campino
Explicitly setting the content-length indeed solves the problem.
I'll check how to get the fix upstream later. However, the buggy code is copied to several locations within the Netrender code, so I need to check for duplicates and fix all of them. Also, I believe that several people use netrender without being affected, so I am afraid that the fix breaks things for them. Is there any advice on how to verify that it does not?
Also, I hit https://developer.blender.org/T54222 as soon as I fixed the first problem. I think I would prefer to fix this as well first.
I've submitted code: https://developer.blender.org/D3741
However, this lacks a reviewer and possibly some tags. I would like it if someone could fill in the missing information.
This issue was referenced by
f975292b1e
