SVG Import Error:
Closed, InvalidPublic
To whom it may concern,
As seen in the attached snapshot, I receive an error every time I try to 'import' a SVG file:
TypeError: load() got an unexpected keyword argument 'axis_forward'
Also, below is my system information related to my MacBook Pro computer and the latest version of Blender I'm using.
Very respectfully,
OJ Jordan
Blender 2.80 (sub 24) System Information
Blender:
version: 2.80 (sub 24), branch: blender2.8, commit date: 2018-10-02 22:34, hash: 9596dfc261f, type: Release
build date: 2018-10-03, 01:05:53
platform: Darwin
binary path: '/Applications/blender.app/Contents/MacOS/blender'
build cflags: -Wall -Werror=implicit-function-declaration -Werror=return-type -Wno-tautological-compare -Wno-unknown-pragmas -Wno-char-subscripts -Wstrict-prototypes -Wmissing-prototypes -Wunused-parameter -mmacosx-version-min=10.9 -std=gnu11 -msse -pipe -funsigned-char -msse2
build cxxflags: -Wall -Wno-tautological-compare -Wno-unknown-pragmas -Wno-char-subscripts -Wno-overloaded-virtual -Wno-sign-compare -Wno-invalid-offsetof -mmacosx-version-min=10.9 -ftemplate-depth=1024 -stdlib=libc++ -std=c++11 -msse -pipe -funsigned-char -msse2
build linkflags: -fexceptions -framework CoreServices -framework Foundation -framework IOKit -framework AppKit -framework Cocoa -framework Carbon -framework AudioUnit -framework AudioToolbox -framework CoreAudio -framework ForceFeedback -liconv -Xlinker -unexported_symbols_list -Xlinker '/Users/fsiddi/bin/buildbot-worker/mac_x86_64_10_9_cmake/blender.git/source/creator/osx_locals.map' -stdlib=libc++
build system: CMake
Python:
version: 3.7.0 (default, Sep 11 2018, 17:36:20)
[Clang 9.1.0 (clang-902.0.39.2)]
paths:
'/Applications/blender.app/Contents/Resources/2.80/scripts/addons_contrib'
'/Applications/blender.app/Contents/Resources/2.80/scripts/addons'
'/Applications/blender.app/Contents/Resources/2.80/scripts/startup'
'/Applications/blender.app/Contents/Resources/2.80/scripts/modules'
'/Applications/blender.app/Contents/Resources/2.80/python/lib/python37.zip'
'/Applications/blender.app/Contents/Resources/2.80/python/lib/python3.7'
'/Applications/blender.app/Contents/Resources/2.80/python/lib/python3.7/lib-dynload'
'/Applications/blender.app/Contents/Resources/2.80/python/lib/python3.7/site-packages'
'/Applications/blender.app/Contents/Resources/2.80/scripts/freestyle/modules'
'/Applications/blender.app/Contents/Resources/2.80/scripts/addons/modules'
'/Users/oraljordan/Library/Application Support/Blender/2.80/scripts/addons/modules'
Python (External Binary):
binary path: '/Applications/blender.app/Contents/Resources/2.80/python/bin/python3.7m'
version: Python 3.7.0 (default, Sep 11 2018, 17:36:20) \n[Clang 9.1.0 (clang-902.0.39.2)]
Directories:
scripts:
'/Applications/blender.app/Contents/Resources/2.80/scripts'
user scripts: '/Users/oraljordan/Library/Application Support/Blender/2.80/scripts'
pref scripts: None
datafiles: '/Users/oraljordan/Library/Application Support/Blender/2.80/datafiles/'
config: '/Users/oraljordan/Library/Application Support/Blender/2.80/config/'
scripts : '/Users/oraljordan/Library/Application Support/Blender/2.80/scripts/'
autosave: '/Users/oraljordan/Library/Application Support/Blender/2.80/autosave/'
tempdir: '/tmp/blender_HkMvFD/'
FFmpeg:
avcodec: '58, 18, 100'
avdevice: '58, 3, 100'
avformat: '58, 12, 100'
avutil: '56, 14, 100'
swscale: ' 5, 1, 100'
SDL:
Version: 2.0.8
Loading method: linked (WITH_SDL_DYNLOAD=OFF)
Other Libraries:
OpenColorIO: 1, 1, 0
OpenImageIO: 1, 8, 13
OpenShadingLanguage: 1, 9, 9
OpenSubdiv: Blender was built without OpenSubdiv support
OpenVDB: 5, 1, 0
Alembic: 1, 7, 8
OpenGL:
renderer: 'AMD Radeon R9 M370X OpenGL Engine'
vendor: 'ATI Technologies Inc.'
version: '4.1 ATI-1.51.8'
extensions:
GL_APPLE_client_storage
GL_APPLE_container_object_shareable
GL_APPLE_flush_render
GL_APPLE_object_purgeable
GL_APPLE_rgb_422
GL_APPLE_row_bytes
GL_APPLE_texture_range
GL_ARB_ES2_compatibility
GL_ARB_blend_func_extended
GL_ARB_draw_buffers_blend
GL_ARB_draw_indirect
GL_ARB_explicit_attrib_location
GL_ARB_gpu_shader5
GL_ARB_gpu_shader_fp64
GL_ARB_instanced_arrays
GL_ARB_internalformat_query
GL_ARB_occlusion_query2
GL_ARB_sample_shading
GL_ARB_sampler_objects
GL_ARB_separate_shader_objects
GL_ARB_shader_bit_encoding
GL_ARB_shader_subroutine
GL_ARB_shading_language_include
GL_ARB_tessellation_shader
GL_ARB_texture_buffer_object_rgb32
GL_ARB_texture_cube_map_array
GL_ARB_texture_gather
GL_ARB_texture_query_lod
GL_ARB_texture_rgb10_a2ui
GL_ARB_texture_storage
GL_ARB_texture_swizzle
GL_ARB_timer_query
GL_ARB_transform_feedback2
GL_ARB_transform_feedback3
GL_ARB_vertex_attrib_64bit
GL_ARB_vertex_type_2_10_10_10_rev
GL_ARB_viewport_array
GL_ATI_texture_mirror_once
GL_EXT_debug_label
GL_EXT_debug_marker
GL_EXT_depth_bounds_test
GL_EXT_texture_compression_s3tc
GL_EXT_texture_filter_anisotropic
GL_EXT_texture_mirror_clamp
GL_EXT_texture_sRGB_decode
GL_NV_texture_barrier
Implementation Dependent OpenGL Limits:
Maximum DrawElements Vertices: 1048575
Maximum DrawElements Indices: 150000
GLSL:
Maximum Varying Floats: 150000
Maximum Vertex Attributes: 16
Maximum Vertex Uniform Components: 4096
Maximum Fragment Uniform Components: 4096
Maximum Vertex Image Units: 16
Maximum Fragment Image Units: 16
Maximum Pipeline Image Units: 80
Cycles:
CPU device capabilities: SSE2 SSE3 SSE41 AVX AVX2
OpenCL device capabilities:
Number of platforms: 1
Platform #0
Platform Name: Apple
Platform Vendor: Apple
Platform Version: OpenCL 1.2 (Nov 13 2017 23:06:50)
Platform Profile: FULL_PROFILE
Platform Extensions: cl_APPLE_SetMemObjectDestructor cl_APPLE_ContextLoggingFunctions cl_APPLE_clut cl_APPLE_query_kernel_names cl_APPLE_gl_sharing cl_khr_gl_event
Number of devices: 3
		Device: #0
			Device Name: Intel(R) Core(TM) i7-4870HQ CPU @ 2.50GHz
			Device Vendor: Intel
			Device OpenCL C Version: OpenCL C 1.2
			Device Profile: FULL_PROFILE
			Device Version: OpenCL 1.2
			Device Extensions: cl_APPLE_SetMemObjectDestructor cl_APPLE_ContextLoggingFunctions cl_APPLE_clut cl_APPLE_query_kernel_names cl_APPLE_gl_sharing cl_khr_gl_event cl_khr_fp64 cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_int64_base_atomics cl_khr_int64_extended_atomics cl_khr_3d_image_writes cl_khr_image2d_from_buffer cl_APPLE_fp64_basic_ops cl_APPLE_fixed_alpha_channel_orders cl_APPLE_biased_fixed_point_image_formats cl_APPLE_command_queue_priority
			Device Max clock frequency (MHz): 2500
			Device Max compute units: 8
			Device Max work group size: 1024
		Device: #1
			Device Name: Iris Pro
			Device Extensions: cl_APPLE_SetMemObjectDestructor cl_APPLE_ContextLoggingFunctions cl_APPLE_clut cl_APPLE_query_kernel_names cl_APPLE_gl_sharing cl_khr_gl_event cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_image2d_from_buffer cl_khr_gl_depth_images cl_khr_depth_images cl_khr_3d_image_writes
			Device Max clock frequency (MHz): 1200
			Device Max compute units: 40
			Device Max work group size: 512
		Device: #2
			Device Name: AMD Radeon R9 M370X Compute Engine
			Device Vendor: AMD
			Device Extensions: cl_APPLE_SetMemObjectDestructor cl_APPLE_ContextLoggingFunctions cl_APPLE_clut cl_APPLE_query_kernel_names cl_APPLE_gl_sharing cl_khr_gl_event cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_image2d_from_buffer cl_khr_depth_images cl_APPLE_command_queue_priority cl_APPLE_command_queue_select_compute_units cl_khr_fp64
			Device Max clock frequency (MHz): 800
			Device Max compute units: 10
			Device Max work group size: 256
Enabled add-ons:
io_scene_3ds (version: (1, 0, 0), path: /Applications/blender.app/Contents/Resources/2.80/scripts/addons/io_scene_3ds/__init.py)
io_anim_bvh (version: (1, 0, 0), path: /Applications/blender.app/Contents/Resources/2.80/scripts/addons/io_anim_bvh/
init.py)
io_mesh_uv_layout (version: (1, 1, 1), path: /Applications/blender.app/Contents/Resources/2.80/scripts/addons/io_mesh_uv_layout/
init.py)
cycles (version: (), path: /Applications/blender.app/Contents/Resources/2.80/scripts/addons/cycles/
init.py)
space_view3d_spacebar_menu (version: (1, 8, 7), path: /Applications/blender.app/Contents/Resources/2.80/scripts/addons/space_view3d_spacebar_menu.py)
space_view3d_copy_attributes (version: (0, 4, 8), path: /Applications/blender.app/Contents/Resources/2.80/scripts/addons/space_view3d_copy_attributes.py)
node_wrangler (version: (3, 35), path: /Applications/blender.app/Contents/Resources/2.80/scripts/addons/node_wrangler.py)
io_import_images_as_planes (version: (3, 2, 0), path: /Applications/blender.app/Contents/Resources/2.80/scripts/addons/io_import_images_as_planes.py)
io_curve_svg (version: (), path: /Applications/blender.app/Contents/Resources/2.80/scripts/addons/io_curve_svg/
init__.py)
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.Oct 4 2018, 2:23 PM
Thanks for the report. The official addons are in the process of being upgraded, SVG is not done yet. See T57001 for progress.
