Blender crashes while playing Alembic animation
Windows 10
GTX 970
Broken: blender-2.80.0-git.0b4c440baa5-windows64
Loaded alembic animation. It was fine until you hit play.
  • Import Alembic file with animation
  • Hit play
  • Program freezes
  • crash
Philipp Oeser (lichtwerk) triaged this task as Needs Information from User priority.Oct 6 2018, 11:45 AM
Cannot reproduce here (linux, 970m)
[Tested with SimpleDeform modifier on a cube as well as non-deforming transforms]
Could you provide a simple .blend file (as well as the exported .abc) so we can reproduce?
Attached is the .blend with a copy of the animation.
The animation was exported from Oculus Quill.
and attached is the .abc file exported from Oculus Quill.
OK, getting a crash with your file, too.
Will have a look later.
Or maybe @Sybren A. Stüvel (sybren) knows right away?
1   MEM_lockfree_freeN                                          mallocn_lockfree_impl.c 161  0x2ef3a9e
2   BKE_nurb_free                                                       curve.c                 443  0x2806d1b
3   BKE_nurbList_free                                                curve.c                 467  0x2806dd6
4   AbcCurveReader::read_mesh                             abc_curves.cc           449  0x22f205d
5   ABC_read_mesh                                                     alembic_capi.cc         989  0x22d6551
6   applyModifier                                                          MOD_meshsequencecache.c 136  0x22af818
7   curve_calc_modifiers_post                                  displist.c              1024 0x282fd94
8   do_makeDispListCurveTypes                             displist.c              1781 0x2831dd4
9   BKE_displist_make_curveTypes                         displist.c              1810 0x2831f00
10  BKE_object_handle_data_update                     object_update.c         229  0x293e14a
11  BKE_object_eval_uber_data                              object_update.c         335  0x293e650
Philipp Oeser (lichtwerk) raised the priority of this task from Needs Information from User to Confirmed, Medium.Oct 6 2018, 8:02 PM
