Blender has suddenly close #57237
Reference: blender/blender#57237
Windows 10 Home 64-bit (10.0, Build 17134) Intel(R) Core(TM) i3-7100 CPU @ 3.90GHz (4 CPUs), ~3.9GHz
Radeon(TM) RX 460 Graphics 8192MB RAM
Broken: Blender v. 2.79b has suddenly stop (close)
Worked: -
Blender had work normally before, but when my PC had been forced shutdown, it will occur that blender has suddenly close after i opened it
it happen in Blender Installer and blender Portable (.zip)
Open file blender and it will suddenly close
I hope you can fix it
Thank you
P.S : Sorry for bad english
*Edit
i had running in command prompt and it says
"Warning! Legacy WGL is unable to select between OpenGL versions.found bundled python: C:\Users\aflac\Downloads\blender-2.78c-windows64\blender-2.78c-windows64\2.78\python"
Added subscriber: @dikasubur
Added subscriber: @lichtwerk
Looks like something went wrong with the graphics driver.
Have you tried updating the graphics driver?
Hi, Philipp!
Thank you for your answer sir..
My graphic driver is up to dated. I have trying to delete the registry related to blender, and try to reinstall blender, but it doesn't change.
And I have used the other version of blender and it doesn;t change too.
Hi, Philipp!
Added subscriber: @StephenSwaney
This suggests it is a local problem with your machine and not something Blender specific.
Hi Stephen!
Thanks for your reply..
Yeah, i think it is a local problem with my PC, but i have tried many things to fix it, and it didn't go well.
i hope someone give me some advice for fixing it.
Video drivers seem to be a common problem with Blender.
You mentioned your driver was up to date. Did you try re-installing it?
Often, the video card manufacturer's driver does OpenGL better than the default Windows Driver
/disclaimer: not a Windows guy
yeah, i think i will try it then...
because i downgrade the driver, but it's nothing happen
thank you
I have tried to re-installing the driver, but it seems nothing change.
I uninstalling the driver with AMD Clean Up Utility and try to open the blender, it seems work properly although it has the warning
and then I try to install the both version of AMD (Adrenalin Edition 18.5.1 & Adrenalin Edition 18.10.1 Optional) but it cannot open and it says again
It seems work properly before, but after updating the windows or something, it cannot work well.
P.S : I use command prompt to run blender with command --factory-startup to know the message on blender
Update
The message "Warning! Legacy WGL is unable to select between OpenGL versions.found bundled python: C:\Users\aflac\Downloads\blender-2.78c-windows64\blender-2.78c-windows64\2.78\python" not appear,
but nothing change in blender.
Blender suddenly close again although the message didn't appear, and i can't fix it yet.
Updated
Finally Blender 2.76a or lower works in my PC but 2.77 or higher cannot work properly.
and i hope this problem can be fixed it
Added subscriber: @ZedDB
This seems to be a computer issue and not a Blender issue. We do not provide support for hardware configuration issues.
