Blender 2.8 Render different camera #57245
Closed
opened 2018-10-15 14:33:04 +02:00 by Franz Tritschel · 9 comments
Hi,
is there a solution to set a different camera as active for rendering in Blender 2.8 with EEVEE.
I’ve already toogled the desired camera as active. Didn’t work.
Then I tried it with the Scene Tab. Didn’t work.
Even if I delete the other camera, the render is still from that position. :face_with_raised_eyebrow:
I also have problems updating python scrips.
https://en.blender.org/index.php/Dev:2.8/Source/LayersCollections/API-Changes
  • context.scene.objects.active
    +context.render_layer.objects.active
  • bpy.context.scene.objects.link()
    +bpy.context.scene_collection.objects.link()
Both new ones don't work.
Many thanks in advance.
Broken: (example: 2.69.7 4b206af, see splash screen)
Hi, is there a solution to set a different camera as active for rendering in Blender 2.8 with EEVEE. I’ve already toogled the desired camera as active. Didn’t work. Then I tried it with the Scene Tab. Didn’t work. Even if I delete the other camera, the render is still from that position. :face_with_raised_eyebrow: I also have problems updating python scrips. https://en.blender.org/index.php/Dev:2.8/Source/LayersCollections/API-Changes - context.scene.objects.active +context.render_layer.objects.active - bpy.context.scene.objects.link() +bpy.context.scene_collection.objects.link() Both new ones don't work. Many thanks in advance. **System Information** Operating system and graphics card **Blender Version** Broken: (example: 2.69.7 4b206af, see splash screen) Worked: (optional) **Short description of error** **Exact steps for others to reproduce the error** Based on a (as simple as possible) attached .blend file with minimum amount of steps
Added subscriber: @Franz_Tri
Member
Member
Please only report one problem per bug report.
I cannot confirm the active camera issue. I can simply select a different camera in the Scene panel and when pressing F12, the scene is rendered from there. Which exact version of Blender do you use (the hash you see on the splash screen)?
About the Python problems: Please remember that the Python API is still not stable.
In your specific case you need to use bpy.context.view_layer.objects.active or just bpy.context.active_object. And bpy.context.collection.objects.link() or bpy.context.scene.collection.objects.link() depending what you are trying to do.
For more questions in this area please use https://devtalk.blender.org/c/python.
Please only report one problem per bug report. I cannot confirm the active camera issue. I can simply select a different camera in the Scene panel and when pressing F12, the scene is rendered from there. Which exact version of Blender do you use (the hash you see on the splash screen)? About the Python problems: Please remember that the Python API is still not stable. In your specific case you need to use `bpy.context.view_layer.objects.active` or just `bpy.context.active_object`. And `bpy.context.collection.objects.link()` or `bpy.context.scene.collection.objects.link()` depending what you are trying to do. For more questions in this area please use https://devtalk.blender.org/c/python.
Thanks for your help.
I tried it with another blend file and it work perfectly fine.
Looks like I destroyed somethink in the file while updating my scripts.
Thanks for your help. I tried it with another blend file and it work perfectly fine. Looks like I destroyed somethink in the file while updating my scripts.
Member
Added subscriber: @lichtwerk
Member
Philipp Oeser self-assigned this 2018-10-16 09:21:20 +02:00
Member
Think we can close this then?
Added subscriber: @NelsonBarryIV
Had same problem. But turned out forgot had added a scene to the video editor. Once deleted everything was fine.
Stupid mistake, but wanted to share in case someone else came here looking for a solution.
Had same problem. But turned out forgot had added a scene to the video editor. Once deleted everything was fine. Stupid mistake, but wanted to share in case someone else came here looking for a solution.
Reference: blender/blender#57245
