Render animation does not respect render single view layer #57247
Reference: blender/blender#57247
Window 10 Pro x64
Nvidia Geforce 1080 Ti
Nivdia Titan V
Broken: blender-2.80.0-git.55e3c17ccc1-windows64
Viewlayer - Render Single Layer option not working per Viewlayer.
If you switch it (Render Single Layer option) on it is on on all view layers. If you switch it off it is off on all view layers. Therefore it is useless and not working as expected.
You are not able to only render one specific view layer by stetting this option.
Open the attached *.blend file.
In the Properties Viewlayer Tab uncheck "Render Single Layer"
Switch the active workspace from View Layer to View Layer.001
Render Single Layer is unchecked there, check it and switch back to View Layer
Render Single Layer is checked altough you unchecked it before. (In the moment this option is not viewlayer exclusive)
Render Single Layer not working per Viewlayer.blend
Added subscriber: @machieb
Added subscriber: @lichtwerk
You are right, this is not a per-viewplayer option, but instead a scene render setting.
So whenever this option is ON, it will render only the currently active viewlayer (so you can "render one specific view layer" -- namely the active one).
Switch to
View Layer
(blender will then only render that), switch toView Layer.001
(blender will then only render that)It's the same as using the "pin" icon in 2.79 described here .
also quoting from d7b472c198:
If you want control over per-viewlayer usage in render, you can use the
User for Rendering
per-viewlayer setting...Closing this as not-a-bug.
Yes I know how it should work. But if you switch to the attached scene scene to the View Layer.001 with the option Render Single Layer on, Blender is rendering not that layer, but the first View Layer because the option is also set there and the first View Layer is only rendered.
So to say it clear. If the option is on it only renders the first renderlayer in the row, whatever View Layer you have currently active in your view and want to render.
It is not possible to render only a special View Layer!
I hope you understand what I mean?
I cannot reproduce.
If I switch to
View Layer.001
I get one cube rendered, if I switch toView Layer
I get two cubes rendered...(this is rendering from the Interface btw.)
View Layer.001
active and the render is wrong (screenshot)?reg. "because the option is also set there": to repeat: the option is a per-scene option (not a per-viewlayer option)
Try this file. The are three View Layer called after the primitives that are inside.
Hit Render Animation (Ctrl-F12)
In the image editor you can see all three View Layer rendered.
Select the cylinder and move it slightly to the left.
Switch to View Layer Cone and move it also a little bit to the left.
Switch to View Layer Cube and move the cube to the left so that you can see a difference to the old rendering.
While you are in the Cube View Layer switch the option Render Single Layer on.
Switch to the Cone View Layer - here the option Render Single Layer is now also on.
Not the Cone View Layer where I´m in, but the Cube View Layer is rendered! Why?
In the Screenshot you can see as described above that, I´m in the cone View Layer and the option Render Single Layer is set to on.
But it renders the Cube View Layer not the View Layer that I´m currently in.
If you switch to the Cylinder View Layer with Render Single Layer on it again renders the Cube View Layer if you hit Ctrl+F12.
View Layer - Render Single Layer option not working per Viewlayerto Render animation does not respect render single view layerAdded subscriber: @brecht
Ok, so the issue is that render animation does not work.
Ah, yes, there's a difference between F12 and Ctrl+F12... (working in master btw.)
This issue was referenced by
345175082b
D3800 actually seems to fix & survive (limited) tests (but not totally sure if other problems might arise...)
