Unwrapping meshes with ngons give bad results
  • Operating System, Graphics card ---
Windows 10, 64 bit, GeForce GTX 1060
  • Blender version with error, and version that worked ---
Blender 2.79 (sub 6), branch: blender2.8, hash: b618c185cb7 , never worked.
  • Short description of error ---
Unwrap Error BlendStar.blend show how bad it is.
And the image .
  • Steps for others to reproduce the error (preferably based on attached .blend file) ---
To reproduce this, just select all faces in the image then do an Unwrap ( any setting it's the same )
The only thing to avoid this is to triangulate the mesh then uwrap then remove triangles.
But the algorithm sometimes doesn't do good with ngons in meshes .
Pretty sure this is a known limitation of the Unwrapping algorithm (ngons - especially non-flat ngons), so you are probably better of using other methods like Smart UV project.
That being set: @Brecht Van Lommel (brecht): do you think there is room for improvement here?
The thing is that coming from other packages we're used to just select faces, then press unwrap and bam. All good . This happens in 2.8 too so maybe If we fix this here then, it will be fixed in 2.8 too .
