Bevel/Triangulate modifier causes crash in edit mode
Broken: rB6add652c3861
Worked: rB6add652c3861~
Bevel modifier or Triangulate modifier causes crash when switching to edit mode. Only happens when "Display modifier in edit mode" setting is enabled.
Also happens when a 'subdivision surface' modifier is above an 'edge split' modifier in the modifier stack and both have "Display modifier in edit mode" enabled.
Add a bevel modifier to default cube and enter edit mode.
Dalai Felinto (dfelinto) triaged this task as Confirmed, Medium priority.
SUMMARY: AddressSanitizer: heap-buffer-overflow //source/blender/draw/intern/draw_cache_impl_mesh.c:4430 in mesh_batch_cache_get_triangles_in_order_split_by_material
Full asan error backtrace: P804
Bug introduced on rB6add652c386198b1e3e126d4a88cd72b5bd97a88.
Same for Triangulate modifier (will also crash in edit mode / show_in_editmode -- with same backtrace)
Philipp Oeser (lichtwerk) renamed this task from Bevel modifier causes crash in edit mode to Bevel/Triangulate modifier causes crash in edit mode.Oct 22 2018, 3:59 PM
