Cryptomatte Pass rendering crashes Blender if 'Accurate Mode' is unchecked and 'Material' pass is selected
Windows 10, Quadro 4000
Broken: 0e268fb68b612e44a74a74631df206c8aaded97b (compiled an hour ago)
Cryptomatte rendering works fine if 'Accurate Mode' is enabled and the Material Cryptomatte Pass is checked. As soon as 'Accurate Mode' it is disabled, Blender closes immediately when starting a rendering with F12. It is worth noting that I was not able to reproduce this every time. Sometimes I had to render twice or three times to have Blender Crash.
The output in the Console is:
Windows fatal exception: access violation
Thread 0x0000395cWindows fatal exception: access violation
Windows fatal exception: Error   : EXCEPTION_ACCESS_VIOLATION
access violationAddress : 0x00007FF697CE3EC4
Windows fatal exception: Address : 0x00007FF697CE3EC4
Module  : C:\blender-git\build_windows_Full_x64_vc15_Release\bin\Release\blender.exe
access violation
  • Start Blender with Factory Settings
  • Use Cycles as Render Engine
  • In the Passes Tab, enable 'Material' Cryptomatte Pass
  • In the same tab, uncheck 'Accurate Mode'
  • Hit F12 -> Crash
Brecht Van Lommel (brecht) triaged this task as Confirmed, Medium priority.Oct 29 2018, 10:47 AM
# backtrace
/home/brecht/dev/build_linux/bin/blender(BLI_system_backtrace+0x33) [0x55df5b0fb4b3]
/home/brecht/dev/build_linux/bin/blender(+0x1688ae6) [0x55df5a66eae6]
/lib/x86_64-linux-gnu/libc.so.6(+0x3ef20) [0x7f0076886f20]
/home/brecht/dev/build_linux/bin/blender(std::__detail::_Map_base<float, std::pair<float const, float>, std::allocator<std::pair<float const, float> >, std::__detail::_Select1st, std::equal_to<float>, std::hash<float>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, false, true>, true>::operator[](float const&)+0x5c) [0x55df5b6e151c]
/home/brecht/dev/build_linux/bin/blender(+0x26eb15d) [0x55df5b6d115d]
/home/brecht/dev/build_linux/bin/blender(ccl::CPUDevice::thread_render(ccl::DeviceTask&)+0xb3a) [0x55df5b49e62a]
/home/brecht/dev/build_linux/bin/blender(ccl::TaskScheduler::thread_run(int)+0x93) [0x55df5b85be13]
/home/brecht/dev/build_linux/bin/blender(ccl::thread::run(void*)+0xe) [0x55df5b85dbee]
/usr/lib/x86_64-linux-gnu/libstdc++.so.6(+0xbd57f) [0x7f0075fb457f]
/lib/x86_64-linux-gnu/libpthread.so.0(+0x76db) [0x7f00780a06db]
/lib/x86_64-linux-gnu/libc.so.6(clone+0x3f) [0x7f007696988f]
I've got the feeling that commit 5e121c8eab23d3d42745277f9c92617cb0aeb066 by Stefan Werner has resolved this issue. So far I had no more crashes.
Indeed appears to be solved.
