Unexpected loop cut behavior with "Topology Mirror"
Open, Confirmed, MediumPublic
Linux (Arch) intel amd64 + NVidia 1070M
2.79b
2-way symmetrical mesh (x and y) could not be properly loop cut when Topology Mirror was enabled. Some midpoint vertices attempted to mirror to the other side of the mesh, causing massive deformation of shape.
http://pasteall.org/blend/index.php?id=50607
Attempt to loop-cut-and-slide the car in half (dividing the longest edges). Mirror modifier is not necessary to reproduce. Only disabling "Topology Mirror" on the tool drawer will allow loop cuts to behave properly. Many other harder-to-describe loop cuts fail to meet expectations (on this same model).
Here's the blend directly uploaded, in case pasteall expires it.
Philipp Oeser (lichtwerk) triaged this task as Confirmed, Medium priority.
Can confirm, will have a look
Note: in 2.8 X Mirror is not working atm. (tried to make that work in D3869)
