Need commit rights to update SVN changes to Vietnamese version of reference manual #57523
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
2 Participants
Reference: blender/blender-manual#57523
I've downloaded the SVN and used
make gettext
sphinx-intl update -p build/locale -l vi
to create a 7.4MB patch file. Tried to create a patch task on
https://developer.blender.org/differential/diff/12318/
but the web app slowed to crawling speed. I ended up thinking this is NOT suitable for this kind of task. So I really need a submitter rights in order to send the changes in directly using 'svn commit'. They are just English text. I haven't transfer any translated texts over yet. The file is attached for references.
Best regards,
Hoang Tran
20181030_initial_commit_for_vn_language.diff
Added subscribers: @hoanguk, @Blendify
You now have commit access. User name and password are synced with this site.
Aaron,
when I use the
it creates files in the 'locales' (with an 's' at the end) and not just 'locale'. Could you please verify that 'locales' (ending with an 's' IS CORRECT). If not, I'll have to delete and recreate again.
Thanks.
Aaron,
I've got the 'Commit failed - connection timed out' error. Please check to see if anything untoward has been happening to the master repository.
This is the screenshot of the error
Please tell me if 'locales' (ending with an 's') is correct or not.
Kind regards,
Hoang Tran
Hi, it is locale without the "s" sorry for the late reply.
Aaron,
That's OK. I'm about to send in some changes in the documentation "contribute.rst" but I have no idea where to place the HTML file so you an others can review the changes. Personally, I don't think reading the patch.diff is enough. Do you have any suggestion?
Regards,
Hoang Tran
We do not need to see the HTML file to review the changes, the patch file of the rst file changes are sufficient.
Submit a patch like before.
