Image Sequence (node material), put absolute path, even if the relative box is checked.
Open, Confirmed, MediumPublic
Mac + Nvidia
2.79b 2018-03-22
Short description of error and steps for others to reproduce the error
When you select a sequence of images in the node of sequence of images to put an animated texture, although this checked the box of relative routes, the node has configured the absolute route, the first time it doesn't even ask if you're going to want it relative. You can check by selecting the node and pressing the key N and in the properties in Source this the absolute set route.
zebus (ofuscado) renamed this task from Image sequence node material put absolute path even if the relative box is checked to Image sequence (node material), put absolute path, even if the relative box is checked..
zebus (ofuscado) renamed this task from Image sequence (node material), put absolute path, even if the relative box is checked. to Image Sequence (node material), put absolute path, even if the relative box is checked..
Brecht Van Lommel (brecht) triaged this task as Needs Information from User priority.Nov 1 2018, 11:32 AM
I can't reproduce the problem.
  • Did you save the .blend file before loading the images?
  • If so, at which location is the .blend file saved?
  • Through which button in the UI are you loading the image?
zebus (ofuscado) added a comment.EditedNov 2 2018, 11:29 AM
Yes
/Users/EDICION5/Desktop/testRelativePathBug/
all the steps I take:
01 Save the scene.
02 select diffuse node and press ctrl + t for create structure nodes with node wrangler
03 delete image texture
04 add image sequence node
at this moment I open the file browser without relative path option
05 I search and select all frames with the a key
06 and click in button Import Image Sequence
my node is in absolute path now
07 click in x for unlink datablock image
08 I press the open button again
at this moment if the relative path and detect sequences checkbox appears, both are activated by default
09 I search and select all frames with the a key
10 and click in button Open Image
Brecht Van Lommel (brecht) raised the priority of this task from Needs Information from User to Confirmed, Medium.Nov 2 2018, 12:01 PM
Ok, that sounds like an issue in the Node Wrangler addon.
