bpy.ops.objects ignores override context
I ran
import bpy
# set selection
bpy.data.objects["Cube"].select = False
bpy.data.objects["Plane"].select = True
# override context
override = bpy.context.copy()
override["selected_bases"] = [bpy.data.scenes[0].object_bases["Cube"]]
override["active_base"] = bpy.data.scenes[0].object_bases["Cube"]
bpy.ops.object.origin_set(override)  # works on Plane
bpy.ops.transform.translate(override, value=(1,1,1))  # works on Cube
expecting to reset origin of Cube which in fact reset the Plane.
version
Blender 2.79b
ubuntu 16.04
Philipp Oeser (lichtwerk) changed the task status from Unknown Status to Resolved.Nov 2 2018, 12:09 PM
operator origin_set relies on selected_editable_objects afaict, so adding override["selected_editable_objects"] = [bpy.data.objects["Cube"]] should do the trick:
import bpy
# set selection
# override context
