Back cull faces not active during render #57643
5 Participants
Reference: blender/blender#57643
Windows 7 x64, Intel i7 4930k, 24 Mb Ram, Nvidia Titan X
Broken: Blender 2.8 alpha - b4dfe00f60
Backface culling (to hide inverted normals) only works on viewport , not on EEVEE render.
I´m using the backface cull method to create realtime outlines and render.
Create a sphere.
Make a simple 3 tone ramp using diffuse->shader to rgb->Color ramp->Material output
Duplicate this sphere. Assign a new diffuse black material. Go to modifiers, Solidify: Flip normals, Material index offset : 1, offset: -0.8747, thickness: 0.5mm.
On the 3d view go to OVERLAYS and check "Back face culling"
Open a uv/image editor. Render EEVEE on the image editor. Only the black ball render appears, this is because the flip normals/cull back faces is not working on render, only on viewport.
Link to the file: http://pasteall.org/blend/index.php?id=50660
3 Tone with Black line.blend
Added subscriber: @PierreSchiller
Added subscribers: @fclem, @lichtwerk
Can confirm that Backface Culling is respected in rendered viewport but not actual render F12.
While I am not sure if this is supposed to be included in render (or this was intended to be an overlay thing only), it is surely weird to have this respected in rendered viewport, but not F12.
I would go either support it for both, or support it for None of [rendered viewport & F12 rendering].
Also not sure how to properly handle this setting if Overlays are disabled [
show_overlays
]? Default is OFF for backface culling, so if this is changed to ON, but overlays are actually disabled, should this mean no backface culling?That being said, you can get around it by using the
Geometry
NodesBackfacing
output to mix in a Transparent BSDF like so (note: you have to change the materials blend mode to something that respects alpha):3 Tone with Black line tweaked.blend
Anyways, I guess @fclem should have a look?
Added subscribers: @WilliamReynish, @pablovazquez
This is a tricky case. Because the backface culling is a per viewport option and when doing F12 render there is no "view 3D" involved, but only the camera. So yes the best way would be to do what @lichtwerk suggested but that comes with a cost so I don't really like this. Maybe @pablovazquez / @WilliamReynish have an idea.
Added subscriber: @brecht
This doesn't look like a bug to me, but a feature that would be good to add. There could be a per object or mesh option for backface culling that each renderer can handle. It's pretty common in other apps and game engines as far as I know.
The feature in the 3D viewport is for inspecting the mesh, not a rendering feature.
Added subscriber: @MilaniSe7en
Changing the blend mode to alpha solved not only my black outline material, but all the problems I had with eevee and backface culling. You are the mannn.
But ye this should be a feature.
Closing as not a bug, this is a feature request.
