Grease Pencil Origin Object Becomes Invisible When Going Into An Armature Pose/Edit Mode #57679
Closed
opened 2018-11-07 17:53:19 +01:00 by Predrag Lazic · 7 comments
OS: Manjaro 17.1.12 Hakoila
Kernel: x86_64 Linux 4.16.18-rt12-MANJARO
DE: KDE 5.50.0 / Plasma 5.13.5
CPU: Intel Core i5-2400S @ 4x 3.3GHz [57.0°C]
GPU: AMD TURKS (DRM 2.50.0 / 4.16.18-rt12-MANJARO, LLVM 6.0.1)
RAM: 2912MiB / 3925MiB
798cdaeeb6
Grease Pencil Object container disappears when an Armature is placed into Pose/Edit mode.
Added File seeThroughGpEmpty.blend
Switch Armature to Pose & Edit mode in added file.
**System Information** OS: Manjaro 17.1.12 Hakoila Kernel: x86_64 Linux 4.16.18-rt12-MANJARO DE: KDE 5.50.0 / Plasma 5.13.5 CPU: Intel Core i5-2400S @ 4x 3.3GHz [57.0°C] GPU: AMD TURKS (DRM 2.50.0 / 4.16.18-rt12-MANJARO, LLVM 6.0.1) RAM: 2912MiB / 3925MiB **Blender Version** 798cdaeeb69 **Short description of error** Grease Pencil Object container disappears when an Armature is placed into Pose/Edit mode. **Exact steps for others to reproduce the error** Added File [seeThroughGpEmpty.blend](https://archive.blender.org/developer/F5427643/seeThroughGpEmpty.blend) Switch Armature to Pose & Edit mode in added file.
Author
Added subscriber: @particl3s
Added subscriber: @antoniov
Your file hasn't strokes in the grease pencil objects.
When you enable pose mode, the object selector is hidden, but if you have strokes on it, you can see them.
I think we cannot consider this a bug because it's working as it was designed.
Your file hasn't strokes in the grease pencil objects. When you enable pose mode, the object selector is hidden, but if you have strokes on it, you can see them. I think we cannot consider this a bug because it's working as it was designed.
Author
Even with strokes inside the Grease Pencil Object the Cube/Cross-hair thing disappears when entering Pose/Edit Mode.
Making it in effect impossible to parent to the armature.
Here's a gif of things on my end.
https://i.postimg.cc/GpHJBP1q/gPGif.gif
Even with strokes inside the Grease Pencil Object the Cube/Cross-hair thing disappears when entering Pose/Edit Mode. Making it in effect impossible to parent to the armature. Here's a gif of things on my end. https://i.postimg.cc/GpHJBP1q/gPGif.gif
In your file when parent to bone, the stroke is moved below and rotate depending of your armature.
After parent, just move the GP object and rotate as needed
ParentBug.mp4
In your file when parent to bone, the stroke is moved below and rotate depending of your armature. After parent, just move the GP object and rotate as needed [ParentBug.mp4](https://archive.blender.org/developer/F5428676/ParentBug.mp4)
Author
I see, GP objects are dependent on Vertex Groups to work. That resolves the issue.
Thanks for your time and patience.
I see, GP objects are dependent on Vertex Groups to work. That resolves the issue. Thanks for your time and patience.
Antonio Vazquez self-assigned this 2018-11-08 08:51:21 +01:00
2 Participants
Reference: blender/blender#57679
