Make the “redo” panel also appear in the tool settings tab #57727
15 Participants
Reference: blender/blender#57727
We should make the 'redo' panel also appear in the Tool Settings tab in Properties:
Added subscribers: @WilliamReynish, @ideasman42, @RamiroCantu, @Regnas
Added subscriber: @DuarteRamos
The floating redo panel could also use some redesign, it currently looks out of place because of the toolbar.
Perhaps centered at the bottom of the viewport, ideally movable/draggable anywhere in the 3D View
Yes, this will be very welcome.
The proposed design confuses do/redo (the settings for a tool and the options to redo with different options are quite different and shouldn't be confused).
Marking design as incomplete.
Even with a design that makes sure there isn't any confusion.
We had the ability to do this, but it ended up being buggy and has since been removed.
If support is added back, the author needs to do it in a way that takes screen editing operations into account, unlike the previous implementation. See
1adfabc8c6
@ideasman42
To be honest, I really don't see room for confusion here.
Those settings would live in a separate and properly named panel, that alone would eliminate any kind of confusion. In fact, what I think is really confusing is the way the "Redo" panel pops up in the viewport at moment.
Annoying flickering? I don't think this is flickering at all. This is actually an expected behavior. When we are using tools we expect to see their settings in the interface.
This might be a bit unrelated, but there's this addon by @JacquesLucke and it's implementation is great. All the settings are in the tool settings tab, no pop ups in the viewport which is nice, because it leaves room in the viewport to show more important info, like in this case the number of instances.
https://www.youtube.com/watch?v=CTbiJiCoeu0
Scatter Objects addon for Blender 2.8 [WIP].mp4
Imo that's how the tool system should work in Blender, it's intuitive and that's how most 3D apps work out there. The "Redo" panel in the viewport should be optional and called by F6 or something, like before.
So yeah, for me this task is very important to improve the workflow in Blender.
@ideasman42 I don't really get the issue. Operator redo always worked before, even though it didn't necessarily appear in the editor that you launched it in. Before we also had this in the top bar which worked too. So I can't see why technically it can't be in the Properties Editor?
Added subscriber: @zeauro
In 2.79, F6 panel could be called without problem of context of any area.
F6 panel does not work in a different window in 2.79.
But a workspace can support a main window and secondary windows dependent of tha main window. That should be sufficient to solve any context problem to have it by workspace.
If user is going fullscreen ; it is to use the redo panel inside the area.
I don't see interest for a user to start an action under a workspace and redoing it using this panel in another one.
But we can imagine it happens. It will not be relative to most actions accomplished in a session.
If it fails, user will be able to cancel action and repeat it in those rare cases. That would be acceptable corner cases.
If it is no more possible with 2.8, it is 2.8 design that fails.
It is is not the proposal to keep a similar functionality of a redo panel not overlapping 3DView that is annoying for user.
An F6 floating panel that can appear over an area that is not 3DView or a panel in a column that is not considered as non-overlapping area of interest that was not a problem in 2.7x to have it resizing at each action. There are years of 2.5x , 2.6x and 2.7x series to prove that such thing as a flickering problem about panel size change does not exist.
There may be problems of hidden settings but no disorientation or epilepsy crisis.
There is no reason to see it as a problem in 2.8 as long as it does not occur over the area of interest.
It is current situation that is annoying.
Yes. Mock-up is confusing. It looks like redo panel and active tool panel were fused.
These are two different things.
Operator exposed in both panel can be totally different.
Active tool can be a select tool or cursor tool.
But what will be in redo panel at that moment can be any operator called by a shortcut.
The distinction of panels by names should be obvious.
In the mock-up, panel label is active tool and operator name occurs inside the panel.
It could be same thing for redo panel. It could be titled redo last action or current action.
Or it could titled using the word "Redo " followed by operator name.
By the way it would also clarify things to have something like that used in area panel, too.
@WilliamReynish the flickering on each action seems like it could be roughly as much as #57712, maybe the panel needs to be at the bottom to prevent it making all other panels move on each action.
I'm not trying to block this suggestion, it would just be good if design tasks list shot-comings and ways to mitigate them.
Only technical issue is needs to fail gracefully when window data is freed.
This is possible of course, support for this was removed since it was a bug in unused functionality at the time.
Added subscriber: @kursadk
This is annoying hell in my use case. I can fire move or scale or rotate couple times a second in edit mode, the ui elements appear and disappear so many times makes me dizzy. If all you do is move things here and there, it might not be an issue but if you like to work fast and efficient, this is not the sitaution one wants to be in. I personally find the current way of handling of hiding other stuff on the screen to show operation info to be an half baked idea.
You must be thinking about something else.
I'm talking about this kind of stuff:
I don't consider this kind of thing as flickering. This is something very natural that happens in every software that has panel that shows properties of several things.
@Regnas the difference is it's common to access tools directly in blender (more then you might switch tools).
You might for eg, extrude and scale many times in a row, if each action changes the UI making panels move vertically, this could be flickering the UI more than we'd like.
@ideasman42 Still not a big deal for me tbh, I can live with that. But if people still think that's too annoying, then your suggestion to keep this panel at the bottom would solve that.
I was referring to what Campbell was referring (which is constant ui changes during operations), plus there is another bug report about similar issue where the viewport widgets disappear during operations, in a sense it is the same thing.
I personally would appreciate if the visible ui is less "excited" during operations. I realize it is a sticky thing to achieve while trying to organize information on the screen and keep clutter away.
thanks
Afaik, this is not a bug, it is meant to work that way (even though there are better places to display that info). And no, it's not the same thing. The situation in the viewport with the header/widgets disappearing and stuff is quite extreme, because it's totally unexpected, unlike the contents in the properties editor. Besides, if you don't want to use that panel in the tool settings tab you always have the freedom to close it. There are no issues here.
Regnas, there are no issues to you, that is perfectly fine. Matter of minor disagreement here. I was trying to make my case about actively active tool panels. Based on the screenshot you provided, the issue is that sizing of the info box constantly changes which I personally find distractiong, however I agree that it is not as extreme as the viewport widgets issue.
Any reason why this task isn't high priority?
The redo panel in the viewport is really really intrusive imo. Also sometimes this panel becomes too big and crowded with settings, and covers a lot of the viewport, which is not efficient at all.
@ideasman42 perhaps you can say if this is realistic to sort out for 2.80 or not?
Am not convinced this is a good solution:
active-tool/scene-toolsettings/active-brush/operator-redo
- all mixed in one space.operator-redo
having a reference to a spesific space in the interface that controls how an operator behaves - that isn't obvious to the user (changes in the shading mode or perspective of the 3D view can impact operator behavior).We could discuss alternatives to this task, eg: orignaly we had this exposed from the top-bar as a popover.
This was removed because the top-bar was often too far away from the view the user was working in.
Now the top-bar is moving into the space, the redo panel could be accessed as a single icon popover (exact behavior would need to be settled on, but think something like this could work).
But this is how it literally works in every 3D software, and they never had issues or confusion, in fact, this way is far far more intuitive. I really don't understand of what confusion are we talking about here.
If someone desires to display this panel in the viewport he should assign a hotkey to the "Adjust Last Operation".
Besides, this is not about moving the redo panel, it's about making the redo panel also appear in the tool settings tab. So there's no loss of any kind here.
Added subscriber: @ThinkingPolygons
We need this.
Every time I see the redo panel big and blocking the view like this, I wish it was in the tool settings already.
It makes perfect sense to be in the tool settings. C4D does that and it's great.
And yeah, since this proposal is to make the redo panel also appear there, nothing would really change for those that want to use it in the viewport. So I can't see why it couldn't be done.
Added subscriber: @brecht
Discussed w/ @brecht and we agreed to do the following.
This can be done once the top-bar is moved into the space.
Since the top bar is essentially a "mirror" of the tool settings tab, does it mean we will have access to that panel there as well? Otherwise it feels like a very unconventional and inconsistent way of solving it, imho.
But still, I don't understand why it can't be done like this original proposal, which is how it's done on most softwares out there.
If it is the only thing that annoys you, adding another Tab just for that panel would be sufficient to solve these issue.
That is not what a user wants and that should be considered as a bug or a fix to do.
If user performs an action in a specific view, rotates view to better perceive what he is doing and then, tweaks redo panel : action should not be drastically modified.
Updating according to view changes should not be automatic but an update provokes by a user action like pressing a button.
Anyways, that confusion exists whatever redo panel's place is.
None of these solutions are satisfying. They require an action from user to keep it open and see those settings. That is leading to a really slow UI to do any modeling work.
Added subscriber: @Ace_Dragon
Hi.
Personally, I don't have a problem with the floating last operator panel in the bottom right corner, as it's often not far from where the operation occurred.
A couple of ideas...
There's always the situation that someone might complain about the amount of mouse travel required, but the only way I see to cut down on that would be to have duplicate UI items everywhere or floating windows popping up everywhere, neither of which might be desirable.
Redo panel as a popover is a bad idea imo.
The redo panel is a panel that needs to be always available/open, since it's accessed very often. Opening and closing a popover all the time won't work for that.
Making it available in the tools settings tab too is still the best solution.
Added subscriber: @TakeshiFunahashi
As for me, at least current status (redo floating panel stick the left corner of bottom, in each 3d view, ) is really annoying (though I gradually accept it).
I think "moving re-do panell as free" and save the position, when save scene can offer more good experience. About many aprication which use floating panell, we can move and locate panell frell,,, (even though it can not record position, user can move them when user need )
User may not complain, if we can decide each option panell position as free.,dock or un-dockable (if lost panell,, we can reset UI as default)
user may complain, when we can not decide where we locate panell as we like. It is not about "clean UI design" (for default UI setting). it is about "flexiblility" the apricaiton offer.
Though my desktop icon are mess-up, but at least I can decide postion of icons. Messing up is my fault. I can not complain about it.
even If my desktop was clean, and short-cut icon location are well organized, I may complain, when I can not move short-cut position.
(eg always "recylce" icon must be top left corner of desktop), This is what I feel about Current blender 2.8 redo-panell. (no move) I hope to decide, "recycle-bin" position.
now I can use "F9" redo (same as blender 2.7), but it can easy disappear without intention, when cursor locate out of the menu range.
Of course, the good thing is it can move as I need. Current ”redo" panel (bottom right coner) and "F9" have pro and con. but do same thing.
Why can not be merged them with keep both good points, as new "redo" panell, which offer more flexibility?
that means, without return old redo as "F9" ,but just offer way to move around in 3d view,for user who hope so. then offer option from preference?
1 "auto hide" (current redo panel)
2 "close , but change labell as "redo". then remain there. then when user do next action, it change labell with context of current action (extrude, rotate, move etc)
About both case, I do not know, why it need to locate as fix postion in 3d viewl. if user hope to see the panel on same place, they do not move it. but user hope to move it, may move as they need.
Added subscriber: @OlafHaag
I must say I'm already confused by the current layout and behavior. I don't quite understand why there are settings in the redo-panel that aren't in the active tools settings panel. Looking at the python commands in the console when changing these options it seems all of them are part of the arguments of the operator function in question anyway. So as a user coming from Maya I don't understand why I can't change these additional settings in the active tools panels after I activated a tool but before I use it. With the current layout I first have to use the tool to then change these additional settings afterwards in the redo panel. But since you can already set these options in the preferences for your keymap beforehand, my intuition is that you should also be able to change these for the active tool before using it.
I acknowledge that there'd be a problem deciding whether one wants to change the current operation or if changing these settings should be applied to the next use of the operator, but I think a simple "Apply" button would do the trick. When operating in the 3d view the last operation is applied when starting a new one.
In that context I like the solution of the extrude widget which uses the arrow to adjust the current operation and the plus-symbol to start a new one.
Added subscriber: @Thane5
Added subscriber: @ckohl_art
Added subscriber: @xdanic
Added subscriber: @APEC
Added subscriber: @TheRedWaxPolice
