Crush on Grease Pencil draw mode
Macbook Mojave v. 10.14.1
2.5GHz intel i7
16 GB 1600MHZ DDR3
AMD RADEON R9 M370X 2048MB
Blender 2.80 alpha 2
Hash: b43ce7908fb
Unavle to use grease pencil when selecting draw mode.
Instant crush!
Philipp Oeser (lichtwerk) triaged this task as Needs Information from User priority.
Cannot reproduce here.
Please follow our submission template and guidelines and make a complete, valid bug report, with required info, precise description of the issue, precise steps to reproduce it, small and simple .blend and/or other files to do so if needed, etc.
A guideline for making a good bug report can be found here: https://wiki.blender.org/wiki/Process/Bug_Reports
Marking as "Incomplete" until the requested information/data is provided.
macOS Macbook Pro Mojave v. 10.14.1
MacBook Pro (Retina, 15-inch, Mid 2015)
2.5 GHz Intel Core i7
16 GB 1600 MHz DDR3
AMD Radeon R9 M370X 2048 MB
Intel Iris Pro 1536 M
blender 2.80 alpha 2
Hash: b43ce7908fb
Check this video,
Don't really need upload a .blend file because it is a new file, and done nothing to it.
still same issue with blender 2.80 hash: e58da0b6e8d
Philipp Oeser (lichtwerk) raised the priority of this task from Needs Information from User to Needs Triage by Developer.
Seems to be something wrong, still cant reproduce though (linux, 970m)...
Not sure what might be causing this (if it is some drawing thing on MAC, maybe @Clément Foucault (fclem) knows? -- or maybe @Antonio Vazquez (antoniov) has seen this before?)
I cannot reproduce it, but the first thing is test using: blender --factory-startup
I had some problems after the changes done in Toolbar, but using factory startup all was solved.
A log of the crash could help also.
eric (ebi) added a comment.EditedNov 12 2018, 10:21 AM
SORRY EVERYONE!!
Reset factory settings fixed the issue.
sorry again for the hassle.
I think we can delete this thread.
Antonio Vazquez (antoniov) claimed this task.
@eric (ebi) No problem, glad you get the solution.
