Remove confirmation dialogs Save or Delete, in favour of displaying messages in the Status Bar #57880
7 Participants
Reference: blender/blender#57880
Currently, some actions spawn confirmation popups, which slows down the workflow and adds confusion if the action was already performed or not. We've solved this problem already for things like the Remove Doubles tool, which immediately performs the action, but then displays a message in the Status Bar to let users know what happened.
There are several prompts we could remove completely, in favour of showing a message in the Status Bar.
For example. there's no need for a Save popup menu with no options other than clicking. In fact, this is a usability issue, because users might think they have already saved when in fact they have only opened a dialog. I've seen users lose work because if this behaviour.
So, rather than showing this when you hit Save, which requires an extra click every time:
We should just save immediately and display a message in the Status Bar, like so:
The same goes for things like deleting. When hitting the
Delete key
, rather than showing a popup that you need to dismiss, we could just use a warning color in the Status bar with a message:It's both easier & faster, and with the message UI, we communicate to the user what is going on.
We could keep the
X key
behaviour the same as now, since it's much easier to accidentally hit than the Delete key.Added subscribers: @WilliamReynish, @Thane5, @orvb, @brezdo, @iss, @0o00o0oo, @ideasman42, @RamiroCantu, @Regnas
Added subscriber: @DuarteRamos
Added subscriber: @sebastian_k
The same conversation popped up few years ago, and I still strongly disagree, especially for deleting things.
For dialogs where the action already happend, like remove doubles, simply showing a message is fine. But I believe this case is already solved, just like you mentioned.
However, I would be strongly against deleting stuff without confirmation. Blender has always been a rather hotkey oriented tool. And it is just too easy to hit X or Delete etc. by accident. Sure, in small scenes you could hit Undo, but in really heavy scenes, where selecting or even deleting can take a couple of seconds or, even worse, could cause a crash, that would be unacceptable.
Most operators in Blender can be cancelled before they where executed, and I love that. Especially delete should also work that way.
Save Over is a bit different, I can see the need to change that. If you hit delete and then move your mouse away without confirmation, you notice that nothing happened. But when you hit Ctrl+S you wouldn't know whether anything or nothing happened. So this needs to be addressed.
@sebastian_k: take the example of a text editor. For every time you attempted to delete a paragraph or hit backspace to delete a character, if the text editor would spawn such a pop up, it’d drive you nuts.
The thing about Blender though, is that we use the X key, which is more likely to be hit by accident. One of the exact reasons why the Delete of Backspace keys are not in the center of the keyboard, is exactly so that you never accidentally press them. But when you do hit Delete, it’s always a deliberate action.
So, one solution could be that the X key still spawns a pop up but hitting the Delete key immediately deletes.
Added subscriber: @ErickNyanduKabongo
I m leaning on letting things the way they are right now. @sebastian_k is pointing good points, and deleting an object from heavy project is really different from deleting a paragraph from text editor like @WilliamReynish wants to argue. The model can be from a project that you have been worked on for many months on a busy scene. Accidentally delete it and everything goes silent, you keep on moving and few months later you realize that you don't have that model anymore.
This implementation will be inconsistent behavior on deleting an object, and what if by accident someone, something, some cat presses the delete button? Will this mean data lost?
Since we can observe people liking this ticket, and the subject is coming up again and again, if implemented, i will suggest to put a check box in User preferences. And please leave the actual behavior as default.
That could be a solution, yes.
I still don't see the need to change the current behavior though.
If you delete in Edit Mode it also brings up a menu that works the same way: If you move the mouse away, nothing happenes. Sure, you have some more options there, but the principle is the same. So I don't see why that would have to be different. Especially because in 3d View deleting an object can have much bigger implications, performance and dependency wise, than in other editors.
Here's what I think we should do then:
We could also add a preference, but if we do it like described here I think that's not necessary.
I really like this proposal, yes, please remove save confirmation. I don't have strong feelings about delete, I'd rather see it go, but your proposal seems quite reasonable middle ground.
Instead of a user preference maybe the "ask for confirmation" could be an operator parameter; that way it could be set on a per instance basis.
Say pressing
Delete
would not ask, butX
would, and pressing some button in a toolbar or an entry in a menu would not require confirmation. Users could then adjust as desired from the keymap options on an individual key basis.Added subscriber: @natecraddock
I think using an operator parameter is the smartest solution. I have the original suggestion implemented here D3953 and I will see if I can update it to have a parameter instead
@Zachman: Sounds good.
Removed subscriber: @brezdo
