Blender 2.8 Crashes when I click on undo and redo while working with image or image empty
Windows 10 Pro 64Bit
Intel(R) Core(TM) i3-4005U CPU @ 1.70GHz, Intel® HD Graphics 4400 (Integrated)
8 GB RAM
Geforce nvidia 820m 2GB (Discrete GPU)
Broken: Blender 2.80.31 2c347ebbba9
Blender Crashes When I click on undo and redo while working with image or image empty.
  1. Opened Blender
  2. Added an Image from Add Menu, Add > Image or Add > Empty > Image
  3. Scaled the Image
  4. Then I clicked "Ctrl + Z = undo, Ctrl + Shift + Z = redo"
  5. Blender crashed
Here is the blend file.
William Reynish (billreynish) triaged this task as Confirmed, Medium priority.
I can reproduce this crash consistently, yes.
Can confirm, getting
add_relation(Eval Order) - Could not find op_from (OperationKey(type: COPY_ON_WRITE, component name: '', operation code: COPY_ON_WRITE))
add_relation(Eval Order) - Failed, but op_to (OperationKey(type: COPY_ON_WRITE, component name: '', operation code: COPY_ON_WRITE)) was ok
looks like it's caused by rB33ac6c25b994, add_relation returns NULL, just checking for that survives (see P825)
backtrace when doing the redo steps provided:
1  DEG::DepsgraphRelationBuilder::build_copy_on_write_relations deg_builder_relations.cc 2496 0x2f09881
2  DEG::DepsgraphRelationBuilder::build_copy_on_write_relations deg_builder_relations.cc 2342 0x2f09333
3  DEG_graph_build_from_view_layer                              depsgraph_build.cc       259  0x2ee655c
4  DEG_graph_relations_update                                   depsgraph_build.cc       320  0x2ee6763
5  BKE_scene_graph_update_tagged                                scene.c                  1419 0x2b5f29e
6  wm_event_do_depsgraph                                        wm_event_system.c        334  0x1c4941c
7  wm_event_do_refresh_wm_and_depsgraph                         wm_event_system.c        359  0x1c49501
backtrace when opening provided file:
7   wm_file_read_post                                            wm_files.c               492  0x1c549b3
8   WM_file_read                                                 wm_files.c               633  0x1c54d73
9   wm_file_read_opwrap                                          wm_files.c               1821 0x1c5784c
10  wm_open_mainfile_exec                                        wm_files.c               1881 0x1c57aad
