Render animation doesn't take in account compositor parameter animation #57939
Closed
opened 2018-11-19 15:36:51 +01:00 by Răzvan Cosmin Rădulescu · 10 comments
 $ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 18.10
Release:        18.10
Codename:       cosmic
 $ uname -a
Linux alienware 4.18.0-10-generic #11-Ubuntu SMP Thu Oct 11 15:13:55 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
 $ lshw -C display
WARNING: you should run this program as super-user.
  *-display
       description: VGA compatible controller
       product: GK107M [GeForce GT 750M]
       vendor: NVIDIA Corporation
       physical id: 0
       bus info: pci@0000:01:00.0
       version: a1
       width: 64 bits
       clock: 33MHz
       capabilities: vga_controller bus_master cap_list rom
       configuration: driver=nouveau latency=0
       resources: irq:30 memory:d0000000-d0ffffff memory:a0000000-afffffff memory:b0000000-b1ffffff ioport:4000(size=128) memory:d1000000-d107ffff
  *-display
       product: 4th Gen Core Processor Integrated Graphics Controller
       vendor: Intel Corporation
       physical id: 2
       bus info: pci@0000:00:02.0
       version: 06
       width: 64 bits
       clock: 33MHz
       configuration: driver=i915 latency=0
       resources: irq:29 memory:d2000000-d23fffff memory:c0000000-cfffffff ioport:5000(size=64) memory:c0000-dffff
Broken: 2.80 alpha 2, hash: f520f01b46
I've only tried the texture node in the compositor but it's possible other nodes are affected too. So when rendering animation, if I try to animate a property on the Texture node in the compositor say (offset) - check attached blender file - the property doesn't actually get updated as the time progresses.
Try to render animation (ctrl f12) and check to see that it's the same image when the texture should be animated via the Offset.Z property of the Texture node.
bug.blend
**System Information** ``` $ lsb_release -a No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 18.10 Release: 18.10 Codename: cosmic $ uname -a Linux alienware 4.18.0-10-generic #11-Ubuntu SMP Thu Oct 11 15:13:55 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux $ lshw -C display WARNING: you should run this program as super-user. *-display description: VGA compatible controller product: GK107M [GeForce GT 750M] vendor: NVIDIA Corporation physical id: 0 bus info: pci@0000:01:00.0 version: a1 width: 64 bits clock: 33MHz capabilities: vga_controller bus_master cap_list rom configuration: driver=nouveau latency=0 resources: irq:30 memory:d0000000-d0ffffff memory:a0000000-afffffff memory:b0000000-b1ffffff ioport:4000(size=128) memory:d1000000-d107ffff *-display description: VGA compatible controller product: 4th Gen Core Processor Integrated Graphics Controller vendor: Intel Corporation physical id: 2 bus info: pci@0000:00:02.0 version: 06 width: 64 bits clock: 33MHz capabilities: vga_controller bus_master cap_list rom configuration: driver=i915 latency=0 resources: irq:29 memory:d2000000-d23fffff memory:c0000000-cfffffff ioport:5000(size=64) memory:c0000-dffff ``` **Blender Version** Broken: 2.80 alpha 2, hash: f520f01b46b **Short description of error** I've only tried the texture node in the compositor but it's possible other nodes are affected too. So when rendering animation, if I try to animate a property on the Texture node in the compositor say (offset) - check attached blender file - the property doesn't actually get updated as the time progresses. **Exact steps for others to reproduce the error** Try to render animation (`ctrl f12`) and check to see that it's the same image when the texture should be animated via the `Offset.Z` property of the Texture node. [bug.blend](https://archive.blender.org/developer/F5637945/bug.blend)
Added subscriber: @razcore
#58644 was marked as duplicate of this issue
Member
Added subscribers: @Sergey, @lichtwerk
Sergey Sharybin was assigned by Philipp Oeser 2018-11-20 15:54:05 +01:00
Member
Can confirm this.
--debug-depsgraph outputs:
on file load
deg_graph_id_tag_update: id=SCScene flags=COPY_ON_WRITE
deg_graph_id_tag_update: id=NTCompositing Nodetree flags=COPY_ON_WRITE
deg_graph_id_tag_update: id=OBCamera flags=TRANSFORM, GEOMETRY, COPY_ON_WRITE
deg_graph_id_tag_update: id=ACCameraAction flags=COPY_ON_WRITE
deg_graph_id_tag_update: id=CACamera flags=COPY_ON_WRITE
deg_graph_id_tag_update: id=GRMaster Collection flags=COPY_ON_WRITE
deg_graph_id_tag_update: id=WOWorld flags=COPY_ON_WRITE
deg_graph_id_tag_update: id=NTCompositing Nodetree flags=TIME, COPY_ON_WRITE
deg_graph_id_tag_update: id=ACCompositing NodetreeAction flags=COPY_ON_WRITE
deg_graph_id_tag_update: id=TENoise flags=COPY_ON_WRITE
deg_graph_id_tag_update: id=IMViewer Node flags=LEGACY_0
Depsgraph built in 0.000341 seconds.
on frame change
[SCScene :: All]: Operation is entry point for update: ANIMATION()
[SCScene :: All]: Accumulated recalc bits for OBCamera: 1
[SCScene :: All]: Accumulated recalc bits for ACCameraAction: 2
[SCScene :: All]: Accumulated recalc bits for CACamera: 3
[SCScene :: All]: Accumulated recalc bits for NTCompositing Nodetree: 6
[SCScene :: All]: Accumulated recalc bits for ACCompositing NodetreeAction: 2
[SCScene :: All]: BKE_animsys_eval_animdata on NTCompositing Nodetree (0x7f14ab9ed408) at time 8.000000
[SCScene :: All]: BKE_animsys_eval_animdata on CACamera (0x7f14ab9ed008) at time 8.000000
[SCScene :: All]: BKE_nodetree_shading_params_eval on NTCompositing Nodetree (0x7f14ab9ed408)
Depsgraph updated in 0.000123 seconds.
on render
Saved: '/tmp/T579390001.png'
 Time: 00:00.09 (Saving: 00:00.04)
etc... nothing else though
BUT: would expect something from the [RENDER] like (when e.g. transform is animated):
[RENDER]: Operation is entry point for update: TRANSFORM_LOCAL()
[RENDER]: Operation is entry point for update: COPY_ON_WRITE()
@Sergey: one for you?
Can confirm this. `--debug-depsgraph` outputs: on file load ``` deg_graph_id_tag_update: id=SCScene flags=COPY_ON_WRITE deg_graph_id_tag_update: id=NTCompositing Nodetree flags=COPY_ON_WRITE deg_graph_id_tag_update: id=OBCamera flags=TRANSFORM, GEOMETRY, COPY_ON_WRITE deg_graph_id_tag_update: id=ACCameraAction flags=COPY_ON_WRITE deg_graph_id_tag_update: id=CACamera flags=COPY_ON_WRITE deg_graph_id_tag_update: id=GRMaster Collection flags=COPY_ON_WRITE deg_graph_id_tag_update: id=WOWorld flags=COPY_ON_WRITE deg_graph_id_tag_update: id=NTCompositing Nodetree flags=TIME, COPY_ON_WRITE deg_graph_id_tag_update: id=ACCompositing NodetreeAction flags=COPY_ON_WRITE deg_graph_id_tag_update: id=TENoise flags=COPY_ON_WRITE deg_graph_id_tag_update: id=SCScene flags=COPY_ON_WRITE deg_graph_id_tag_update: id=NTCompositing Nodetree flags=COPY_ON_WRITE deg_graph_id_tag_update: id=OBCamera flags=TRANSFORM, GEOMETRY, COPY_ON_WRITE deg_graph_id_tag_update: id=ACCameraAction flags=COPY_ON_WRITE deg_graph_id_tag_update: id=CACamera flags=COPY_ON_WRITE deg_graph_id_tag_update: id=GRMaster Collection flags=COPY_ON_WRITE deg_graph_id_tag_update: id=WOWorld flags=COPY_ON_WRITE deg_graph_id_tag_update: id=NTCompositing Nodetree flags=COPY_ON_WRITE deg_graph_id_tag_update: id=ACCompositing NodetreeAction flags=COPY_ON_WRITE deg_graph_id_tag_update: id=IMViewer Node flags=LEGACY_0 deg_graph_id_tag_update: id=TENoise flags=COPY_ON_WRITE Depsgraph built in 0.000341 seconds. ``` on frame change ``` [SCScene :: All]: Operation is entry point for update: ANIMATION() [SCScene :: All]: Operation is entry point for update: ANIMATION() [SCScene :: All]: Accumulated recalc bits for OBCamera: 1 [SCScene :: All]: Accumulated recalc bits for ACCameraAction: 2 [SCScene :: All]: Accumulated recalc bits for CACamera: 3 [SCScene :: All]: Accumulated recalc bits for NTCompositing Nodetree: 6 [SCScene :: All]: Accumulated recalc bits for ACCompositing NodetreeAction: 2 [SCScene :: All]: BKE_animsys_eval_animdata on NTCompositing Nodetree (0x7f14ab9ed408) at time 8.000000 [SCScene :: All]: BKE_animsys_eval_animdata on CACamera (0x7f14ab9ed008) at time 8.000000 [SCScene :: All]: BKE_nodetree_shading_params_eval on NTCompositing Nodetree (0x7f14ab9ed408) Depsgraph updated in 0.000123 seconds. ``` on render ``` Saved: '/tmp/T579390001.png' Time: 00:00.09 (Saving: 00:00.04) etc... nothing else though ``` **BUT**: would expect something from the [RENDER] like (when e.g. transform is animated): ``` [RENDER]: Operation is entry point for update: TRANSFORM_LOCAL() [RENDER]: Operation is entry point for update: COPY_ON_WRITE() ... ``` @Sergey: one for you?
Added subscriber: @brecht
Technically, @brecht is the boss of render pipeline.
From a developer's point of view, i do not see any calls to DEG_evaluate_on_framechange(). So my guess is that this is something where old dependency graph had hacks to do animation evaluation directly in various places.
Technically, @brecht is the boss of render pipeline. From a developer's point of view, i do not see any calls to `DEG_evaluate_on_framechange()`. So my guess is that this is something where old dependency graph had hacks to do animation evaluation directly in various places.
Sergey Sharybin was unassigned by Philipp Oeser 2018-11-21 09:24:24 +01:00
Brecht Van Lommel was assigned by Philipp Oeser 2018-11-21 09:24:24 +01:00
Member
assigning to @brecht then
Added subscriber: @xarts
This issue was referenced by 9375c941b7
This issue was referenced by 9375c941b75462b1e03274b7f7a23a0ae81d00e4
5 Participants
Reference: blender/blender#57939
