VSE: AV-Sync causes caching to fail
Closed, InvalidPublic
Ubuntu Linux, GTX 1080
Broken: Blender 2.8, 2.79b
How to reproduce:
  • Load a clip in the VSE
  • Set playback method to AV-Sync
  • The sequence will not be cached and will not play at the target frame rate.
Setting playback to No Sync makes caching work.
Physics caching also doesn't work with this option. It seems like caching in general doesn't work with AV Sync.
Brecht Van Lommel (brecht) changed Type from Bug to To Do.
Brecht Van Lommel (brecht) triaged this task as Confirmed, Medium priority.
Richard Antalik (ISS) closed this task as Invalid.
Richard Antalik (ISS) claimed this task.
I can not confirm this.
With A/V sync enabled, frames are skipped and therefore there are "holes" in the cache. You would have to play section several times to be fully cached.
D3934: VSE cache with frame prefetching (WIP) will make it easier to fill the cache in advance + actually see the cache.
This is not a bug.
Only way around this, is threaded significantly faster rendering and preview drawing.
Prefetching is threaded rendering, so it's just a partial solution.
