FBX version options & Nuke .chan add-on issues in v2.79 and v2.8
Broken: (example: 2.69.7 4b206af, see splash screen)
blender2.79 ( worked with issue )
blender-2.80-e829e47b558-win64 ( missing FBX version options & Nuke .chan add-on )
blender2.79
bug: FBX export in ver. FBX 6.1 ASCII
issue: one frame offset in the head frame when imported to Nuke compare to Alembic cache exported from the same scene
bug: FBX export
issue: 1. missing version option drop down menu ( I know ver. 6.1 ASCII is old and no longer being supported, but it'd be great to have it as an option for Nuke or other purposes )
  1. the current version of FBX is having scale and orientation issues when imported to Nuke comparing to the Alembic cache
bug: Nuke .chan add-on
issue: missing in the Add-ons menu
Stephen (SWDesign) updated the task description. (Show Details)
Philipp Oeser (lichtwerk) triaged this task as Needs Information from User priority.Nov 25 2018, 3:40 PM
Please avoid multiple issues in a single report.
(Just makes it hard to address these one at a time)
  • reg. FBX ASCII in 2.8: this has been removed on purpose (see T53877)
  • reg. FBX ASCII in 2.79 frame offset: chances are very slim that this will be addressed, all resources are focused on the current (binary) exporter
  • reg. Nuke .chan addon: this hasnt been updated to 2.8 yet and thus is not available for the time being...
Now that leaves us with:
  • There are a couple of options regarding transforms in the exporter (see rBA8b2a241baca0 [and possibly the related tasks mentioned in that commit message]), have you tried these?
  • Is this just an issue with Nuke? (is a roundtrip blender > FBX > blender OK?)
  • In any case we would need an example .blend (and a precise description of how this fails in Nuke), could you share this here?
Marking as incomplete until we hear back...
Stephen (SWDesign) added a comment.EditedNov 26 2018, 8:41 AM
Hello Philipp,
Thanks for confirming this will eventually be put back in 2.8 in the future version
This is an issue for both Nuke and Blender roundtrip (blender > FBX > nuke) & (blender > FBX > blender)
forgot to mention the animation info also disappeared
The alembic cache appears to be nearly 1:1 in blender so in this case I'm using the alembic as the correct reference.
Nuke 3d viewport screen cap:
Alembic is highlighted very tiny on the ground plane in comparison to the gigantic FBX
Blender 3d viewport screen cap:
Alembic is highlighted and matching 1:1 to Original Suzane
FBX is mis-positioned and animation info are lost
geoExportTest file ( including both Nuke and Blender scene) is attached below
Thanks,
SW
Philipp Oeser (lichtwerk) raised the priority of this task from Needs Information from User to Needs Triage by Developer.Jan 9 2019, 7:34 PM
Information is given, needs another look...
Sebastian Parborg (zeddb) triaged this task as Confirmed, Medium priority.Feb 11 2019, 1:13 PM
I can confirm that with blender -> fbx -> blender , the animation is lost and the object is miss positioned.
Bastien Montagne (mont29) closed this task as Archived.Feb 11 2019, 1:57 PM
Animation info is not 'lost', it's just 'disconnected' (due to how FBX anim system works (and is cryptic), it's not really possible to keep/convey the concept of Action through it). You simply have to re-assign the right action to the right object after re-importing into blender. Disabling All Actions and NLA options in FBX export settings would also help here, I guess (should generate much less animation data).
As for relation between empty and monkey, you are using a constraint, this is not supported by the exporter currently, only plain basic parenting is (…to some extend, it's not always working perfectly well :| ).
But by all means, if Alembic is working for your pipeline, please, please use Alembic! You'll be using an open, well documented and future-proof format, while FBX is a broken-by-design, totally opaque closed-sourced format… And in general, it's much better/safer to use fully baked formats (like Alembic) for exchanges, complex setups involving animation, armatures, constraints etc. are seldom properly converted between different apps.
