Issue with rigid body and modifiers dependent on transform #58044
17 Participants
Reference: blender/blender#58044
Windows 10, GTX1070
Broken: Blender 2.83
Working: Blender 2.79 ( <- Updated info )
When adding hair to a rigid body, the hair position doesn't update.
The ball will fall, but the hair doesn't follow it.
Have a look at the attached blend - beside the rigid body cube, I've animated a second cubes position to fall, and the hair follows it correctly
hair_particles_on_rigid_body.blend.
Added subscriber: @MalDuffin
#68128 was marked as duplicate of this issue
#71011 was marked as duplicate of this issue
#69419 was marked as duplicate of this issue
#69407 was marked as duplicate of this issue
#66935 was marked as duplicate of this issue
#66828 was marked as duplicate of this issue
#60079 was marked as duplicate of this issue
#65541 was marked as duplicate of this issue
#63761 was marked as duplicate of this issue
Note that, if you carry out the above steps and skip 7), the ( non-hair ) particle effects do follow the cube.
Added subscribers: @fclem, @Sergey, @lichtwerk
Can confirm this.
This could just be a drawing issue (e.g. if you go into Particle Editmode the hair is actually in the right spot).
Havent checked code. If this drawing only, I would kindly ask @fclem to have a look, but it might also be one for @Sergey to check
Another interesting related issue. If you replace step 4) Rigid Body with 4a) Soft Body and optionally 4b) Toggle off Goal, then the hair particles do follow the new physics position of the cube when you press play after step 8)
So, hair seems to work with Soft Body physics updates and not Rigid Body physics updates.
When in particle mode...
, but ( if you enable hair dynamics )
In edit mode...
but
Added subscriber: @gogo
@Sergey - I see you just fixed another issue with rigid bodies and particles, could you have a look at this one too?
Would need to have a closer look, but could be caused by the change in the evaluation order of rigid body, similar to #63028.
The issue here is that such setups are causing feedback loop in the system:
This appeared to work in 2.7 better, but was always causing one frame offset during animation. Which isn't really helpful, since it causes self-intersections which are impossible to fix. Additionally, rendering motion blur becomes a huge issue in those configurations.
Hi Sergey,
Thanks for having a look.
Hopefully it can be fixed, think of all the hairy domino simulations that need rendered! :P
Added subscribers: @gase12, @ZedDB
Added subscribers: @keinerweiss, @StephenSwaney, @grosgood
Added subscribers: @dadou99, @sreich, @3di, @SmartySmart702, @brecht
Issue with adding hair to rigid bodyto Issue with rigid body and modifiers dependent on transformAdded subscriber: @badbytes
Just tested the release candidate and the bug is still here. Strangely it did appear to work once, with strange results, but after that it went back to only taking into account frame one of the rigid body simulation.
Added subscriber: @jricardo_rr
Guys, the entire physics system is broken, has this accidentally been overlooked? Really surprised 2.8 was released without this being fixed first.
check the file below which shows how this affects all interactions (not just hair).
physics broken.blend
Please leave setting priorities to developers.
OK Sorry, I just assumed the physics system no longer functioning would have been enough to warrant a 2.8 release delay, so I just wanted it to get immediate attention as I presumed this must have been lost in all of the bug reports over the past couple of months.
Added subscriber: @zakleap
Constraints are also ignored by rigid body physics. Animations have been greatly restricted by the lack of physics capability.
I will dare raising this to High.
@brecht, @Sergey: shouldnt we try tackling this for 2.81?
(just correct me if I am wrong though...)
Removed subscriber: @fclem
Added subscriber: @EricBu
Added subscriber: @Eary
I posted another similar post before being led to this one, I figured that after you do all the steps, don't play the animation yet, save the project, and close blender. Delete the .blend1 file beside the .blend file, the open it up again, and play the animation, the hair particles are now following the cube.
Base on that, I believe this has something to do with the .blend1 file. I am not a programmer, I don't know what the .blend1 file is, but I guess it is some kind of cache file. My theory is that although blender understands the hair should be following, the cache file (.blend1 file) is not updated, therefore the hair particles don't follow the cube as they should.
Added subscriber: @davis095381-2
Try again and reopen blender without deleting .blend1 file, because .blend1 file is just a backup of the saved .blend file.
You are right, I tried it just now and it worked, perhaps it's not the .blend1 file, it is some kind of other problem. It is still the case though, that something is not updated, reloading Blender just refreshes it.
By the way, in order for it to work, set the shape to Mesh and set the source to Base under the "Collision" settings of the Rigid Body tab. I mentioned this in my post, which is closed now, it doesn't seem to be mentioned right here.
@Sergey : I have added this to 2.81 milestone (since it was set to "High"), mind checking again?
Added subscriber: @fraetz
This needs bigger design changes to the dependency graph and physics, and while it would be good if we can, it is not a requirement to be fixed for 2.81.
Added subscriber: @Hookflash
Added subscriber: @vr_sebas
Added subscriber: @EAW
Added subscriber: @RodDavis
Added subscribers: @sangwook71, @mano-wii, @LucaRood-3, @JacquesLucke
Closed as duplicate of #77685
