Curve segment hair not smooth when set to thick #58065
Reference: blender/blender#58065
I find that the geometry of hair is no longer smoothly rendered when switching from 'Ribbons' to 'Thick' (using curve segments for both). The hair seems to actually be a smooth curve for Ribbons (first image), but line segments (of the given curve subdivision level) for 'Thick' (second image).
Also the normals become discontinuous as can be seen from the image (shader is setup to display the normals as colors).
broken-thick-hair.blend
Blender version: 2.79b, Hash 32432d91bbe, Arch Linux package 17:2.79.b.git3.32432d91-11
Added subscriber: @omgold
Added subscribers: @brecht, @mont29
@brecht, guess that one is for you to check? ;)
The hair curve primitive is optimized for performance, not so much for exact results when viewing hair under a microscope.
It might be possible to improve render quality or precision, but we do not consider this a bug.
I fear I can't follow you there. Why is the curve smooth for ribbons? Why is it called curve at all, then, when it is effectively line segments with an extra subdivision option?
Also the issue about the discontinuous normal quickly becomes visible from larger distances, when using shaders other than hair (which hide the issue better, than e.g. diffuse or glossy). It requires a very fine subdivision to go away.
Here is an example. Straight, uncombed hair, diffuse material:
hait-diffuse.blend
It basically means thick curve segments are unusable for anything other than hair shaders.
