Duplicated previews for Matcaps and HDRI's if config folder is present #58104
Reference: blender/blender#58104
Windows 10 x64, AMD Radeon R9 390
Broken: Every 2.8 version
When the user creates a config folder in the root folder containing Blender 2.8 all of the matcap and world preview images show up as duplicates.
Extract Blender 2.8 (any version) to a folder on your computer -> Create a "config" folder inside the "2.80" folder as you would when creating a portable version of Blender -> Start Blender and open up the shading window in the 3D view and select a matcap/studio
Added subscriber: @ninthjake
#58305 was marked as duplicate of this issue
Added subscriber: @lichtwerk
Confirmed, will have a look
Added subscribers: @fclem, @brecht
Hm, after checking, this is true only for portable builds (meaning that you create the
config
folder inside a locally extracted self contained blender)That check for portable builds is here .
See also https://docs.blender.org/manual/en/dev/getting_started/installing/configuration/directories.html
If you do it like this, then
bpy.utils.user_resource('DATAFILES')
/BKE_appdir_folder_id(BLENDER_USER_DATAFILES)
will return the same path as the 'builtin' datapath (BKE_appdir_folder_id(BLENDER_SYSTEM_DATAFILES)
)... it's always LOCALThat being said, if you put custom studiolights in the datafiles folder in your
USER
directory (instead ofLOCAL
-- see the manual again) and remove the config folder from the extracted location again, all should be fine and dandy...Of course this could be worked around by introducing something like a "USER" folder inside the LOCAL datafiles folder, but I am unsure if this is against design (and worth the effort)
After all, I guess this is somewhat expected behavior and can be closed?
(unless @brecht or @fclem have objections?)
Blender should not look in the same folder twice, I would consider that a bug. We just need to check if
andBLENDER_SYSTEM_DATAFILES
return the same path, and if so only go over it once.Oki, will do
Added subscriber: @Harvester
This issue was referenced by
378e5232e8
