Error loading file ( rigid body / soft body / hair dynamics )
Windows 10, GTX 1070
Broken: Blender 2.80 Alpha 2 edbf15d3c04
Loading of the file crashes Blender.
It's a simple example scene, created like so...
  • Create 2 cubes
  • Make one rigid body
  • Make one soft body. with no goals
  • Attach particles to each one, including hair dynamics.
  • Save the file
  • Try to re-load it - crash
Load the .blend file, the crash should occur straight away
Confirmed on build a740cc53ea1 on macOS. Running from console produces the following error:
Read blend: /Users/admin/Downloads/rigid_soft_hair_2.blend
Dependency cycle detected:
  'OBCube.GEOMETRY_UBEREVAL()' depends on 'OBCube.TRANSFORM_FINAL()' through 'Partcile Eval'
  'OBCube.TRANSFORM_FINAL()' depends on 'OBCube.TRANSFORM_OBJECT_UBEREVAL()' through 'Temp Ubereval'
  'OBCube.TRANSFORM_OBJECT_UBEREVAL()' depends on 'OBCube.RIGIDBODY_TRANSFORM_COPY()' through 'RBO Sync -> Uber (Temp)'
  'OBCube.RIGIDBODY_TRANSFORM_COPY()' depends on 'SCScene.RIGIDBODY_SIM()' through 'Rigidbody Sim Eval -> RBO Sync'
  'SCScene.RIGIDBODY_SIM()' depends on 'SCScene.RIGIDBODY_REBUILD()' through 'Rigidbody [Init -> SimStep]'
  'SCScene.RIGIDBODY_REBUILD()' depends on 'OBCube.GEOMETRY_UBEREVAL()' through 'Object Geom Eval -> Rigidbody Rebuild'
Detected 1 dependency cycles
blender(11772,0x700006b2c000) malloc: *** error for object 0x7f8f32ee7d60: pointer being freed was not allocated
blender(11772,0x700006b2c000) malloc: *** set a breakpoint in malloc_error_break to debug
Sebastian Parborg (zeddb) lowered the priority of this task from Needs Triage by Developer to Needs Information from User.Feb 4 2019, 1:42 PM
Is this still an issue with the latest beta?
As of macOS 10.14 build 38984b10ff7b it seems to open just fine, so it appears to be resolved.
Mal Duffin (mal_cando) closed this task as Resolved.Feb 4 2019, 5:09 PM
Mal Duffin (mal_cando) claimed this task.
I just tried it, the loading seems to be fixed.
