Preview mono audio not the same as render #58153
Reference: blender/blender#58153
Operating system: Windows 7
Graphics card: Vega 64
Broken: 2.80 Beta
43e7c5dd43
29/11/2018Worked: 2.79b release
Preview playback of audio strips set to mono don't behave the same way compared to 2.79b.
2.80b renders the audio channels correctly but doesn't preview them the same way as the render.
2.79:
2.80:
May require a surround speaker setup
Open:
Audio_Panning Mono.blend
Listen to the playback differences with mono checked and unchecked.
Added subscriber: @ChristopherAnderssarian
@neXyon Mind having a look?
@neXyon Polite Nudge...
Hey, what audio backend/device are you using? OpenAL? If so, does it work with SDL? What operating system are you on? Do you have an audio driver installed? If so, which one and which sound card do you have if any?
Sorry, a complete derp on my end...
(note: My full system specs are on my profile )
Here is my audio setup:
I use the default OpenAL, but I tried with SDL, but I get nothing. The animation plays, but there is no audio. (both in 2.79 and 2.80)
I disabled all enhancements / sound effects.
Hmm, SDL should work though, can you play around with the settings a bit? The sample rate 48 kHz should work fine, you can try changing the number of channels in the user preferences. Also please try setting the environment variable SDL_AUDIODRIVER to dsound or waveout and check if that helps to get SDL to work. See https://sdl.beuc.net/sdl.wiki/SDL_envvars#head-9ae11b2daf93dc3706eccf15cbf26eb6235ac634
Please also try a 2.79 version from the build bot here: https://builder.blender.org/download/
I suspect that the problem with OpenAL is caused by a library update and thus should exists there as well. The precise change in OpenAL soft that I'm suspecting is here:
de51ba088e
- it basically removes the front speaker from the 5.1 setup and that causes the audio rendering to differ between playback and output.Finally, if you can confirm that this change in OpenAL soft is the cause, there's one thing you can do to get the same output in playback as in rendering. You have to create an openal soft configuration file named $HOME/.alsoftrc and have the following content:
(see https:*raw.githubusercontent.com/kcat/openal-soft/master/alsoftrc.sample) and for
<<FILE>>
you have to fill in the filename where you downloaded this file: https:*raw.githubusercontent.com/kcat/openal-soft/master/presets/itu5.1.ambdecThis should bring back the configuration before the library update.
Yep, I'm getting the same result with daily build: 2.79 Windows 64 bit December 29, 01:50:18 -111179beb0b1-.
I also confirmed this is happening in Linux (the nono audio not behaving in the same way as 2.79).
I'm still having trouble getting SDL to work. I've spun up an old Debian VM (with 2.80 Beta -266b1e2cdbc1-) with no drivers manually installed and Blender crashed upon switching to SDL.
Do audio drivers need to installed for this to work?
Okay, okay... so....
I've got 8 channels (speakers) so I just leave the sound preferences at 7.1 and adjust the scene audio to the project's need (as you know from #49241#489952) will the configuration you suggest work for 7.1?
And will the panning stay the same as in 2.79?
At what point does this become a Blender issue? I assume the way Blender handles mono audio panning is unique.
More testing...
This is a simple switch from mono checked to unchecked.
Left is the 2.79 release, right is the latest builds.
This is a Surround Pan left is the latest builds, right is the 2.79 release.
There is a lot of leaking between the channels
So my suspicion seems to be correct. The difference in playback is cause by the changes in OpenAL soft which now uses ambisonics (https:*en.wikipedia.org/wiki/Ambisonics) based surround sound. Originally, I implemented Blender's speaker mapping based on OpenAL soft. That's why so far they have been the same. Ambisonics is actually better and ideally Blender would also go this direction for 3D sound. Unfortunately, I don't have the resources for this development right now, it's more a long term goal. If you need an short term solution, please use the configuration files as I have mentioned them. There are also ambdec files for different speaker setups including 7.1 here: https:*github.com/kcat/openal-soft/tree/master/presets.
No worries, it's a relatively minor inconvenience and does not affect the final render (or mixdown).
Added subscriber: @iss
Is this still an issue?
If yes, Should I keep VSE tag?
I am trying to cleanup workboard a bit..
Yes, this is still an issue. It's a minor inconvenience for me, but others may find it a blocker in their work flow.
@iss Out of curiosity, are going to categorize tasks like in #bf_blender_2.8 ([here ]]) or #code_quest ([ https:*developer.blender.org/project/board/80/?hidden=true | here )?
You can further categorize them by when they should be implemented or by specific areas or by both.
Feels to me wasted functionality of phab, but I thought I'd let you know/decide :)
Right now I am focusing on bugs.
If there is VSE bug not tagged, I guess other devs will relay this to me If I don't catch it.
I can/should look at approved design decisions made in code quest, but now bugs are the priority.
@ChristopherAnderssarian have you tried the speaker setup configuration files as I mentioned?
Been a while since this project (and I haven't had this use case recently) But I think 3D7.1.ambdec showed something promising...
I remember I ended up sticking to 2.79b for the completion of the project, for various other reasons...
Currently I can't do much testing, not sure though if @iss can confirm the config files fix the issue in current master.
Added subscriber: @neXyon
I looked into this:
First I tested file by playing in VLC - OK
No audio with SDL, havent tried workaround.
With openAL it indeed seems that FC channel gets no signal
With mono checkbox enabled, I get signal on FL and FC, but also on BL and BR, just -30dB lower than front.
Signal from FL gets in various attenuation levels to FR, BR and FLC. Similar goes for FR.
When I set 'audio device' channels to 5.1 surround, I still get signal on 7 channels.
I have this error on startup:
AL lib: (EE) SetChannelMap: Failed to match front-center channel (2) in channel map
I created
.alsoftrc
file with contentDownloaded .ambdec files to specified path. No change in output levels.
Would be good if I could confirm, that files has been read, so I put string
sdfsdfsdf
at the beginning of file - no errors or anything.Perhaps I should place this
.alsoftrc
file elswhere? Should I put something in PATH?Finally I have no idea how to render multichannel audio output - I got only 2 channels when I did mixdown audio and used wav as codec.
When I am here, I may as well do the thing..
I'd love to hear what this does, I haven't ever got this to work either...
This might be the audio driver spreading the audio around, it happens for me too.
This is what confused me as well. In alsoftrc.sample it says this:
I read this to mean: Linux users do the first two lines, Windows users only line three concerns you.
Are Windows users supposed to just copy-and-paste the contents of
surround71
into an .ini file?Audio in Blender is fun.
This comment explains a bit though...
Please have a closer look into this one! Maybe an SDL version upgrade makes it work again. Or you may try setting the
SDL_AUDIODRIVER
environment variable: https://wiki.libsdl.org/FAQUsingSDL#Win32-1Where did you put the
.alsoftrc
file in the first place? As @ChristopherAnderssarian wrote, the docs state, that the file has to be in the%APPDATA%
directory (you can input that directly into the address bar of the file explorer.You can set the channels in the Properties -> Scene Properties -> Audio -> Audio Channels
After setting scene audio to 7.1ch I got correct render.
I haven't read that far in the .alsoftrc example.. So now I put it in
%APPDATA%
asalsoft.conf
.There is no error
in console after restarting blender, so seems that file was read.I confirm by putting in rubbish and get
AL lib: (EE) LoadConfigFromFile: config parse error: malformed option line: "sdfsdasdgadsgf"
I get some signal on FC channel, but playback is still not same as render. There seems to be some cross-mixing.
I would give example, but I don't have setup to record 8ch audio. Perahps OBS can do this, will check.
Okay, I had a close look at those configuration files and how they work. It's impossible to get the old behavior of OpenAL Soft from before the introduction of ambisonics. So there's nothing we can do unfortunately to make them work the same.
SDL would give the same output and rendering though, so it would be nice to get that to work!
