Object/color picker only works within the same window
Open, Confirmed, MediumPublic
Operating system:
Windows 10 x64
Broken:
Date: 2018-11-29
Hash: 43e7c5dd434
Branch: blender 2.8 (Beta)
Trying to select a color using the picker gives a black color. This happens when opening Preferences as a separate window.
Brecht Van Lommel (brecht) lowered the priority of this task from Needs Triage by Developer to Needs Information from User.Nov 29 2018, 7:43 PM
I can't reproduce this problem. Please:
  • Mention your graphics card
  • Explain exactly which color you are modifying, and which kinds of operation within the color picker you are doing? Does it immediately show black when you open? Is it when using the eyerdropper, inside or outside the preferences window?
Zachary (AFWS) added a comment.EditedNov 29 2018, 8:03 PM
@Brecht Van Lommel (brecht)
GTX 950M
It's selecting red now. What I found out if I select a color within the Preferences window it would be correct. If I try to select outside the Preferences window, that is when it becomes black or now red.
Both screenshots I was selecting the gray in the 3D View. The Preferences that is a separate window picked red. The "built-in" preferences picked the gray of the 3D View. The setting I was changing was Text under Regular.
Preferences separate window
Built-in Preferences
Here's a 50 second video.
https://www.youtube.com/watch?v=2yemstzez9o&feature=youtu.be
Zachary (AFWS) renamed this task from Theme settings color picker gives black color to Theme settings color picker gives black or red color.Nov 29 2018, 9:46 PM
Christopher_Anderssarian raised the priority of this task from Needs Information from User to Needs Triage by Developer.Nov 29 2018, 10:05 PM
Can confirm...
Here's a .blend:
Brecht Van Lommel (brecht) renamed this task from Theme settings color picker gives black or red color to Object/color picker only works within the same window.Dec 11 2018, 7:26 PM
Brecht Van Lommel (brecht) lowered the priority of this task from Needs Triage by Developer to Confirmed, Medium.
