Blender 2.8 - Adding new collection from the Objects Menu, does not add the collection to the scene
Closed, DuplicatePublic
Operating system: Ubuntu 17.10
Graphics card: GTX 1080
Broken: blender2.8 23284e4dde5
Worked: master 786870e26f8
  1. Click on the default cube
  2. go into the objects section of the Properties menu
  3. in the collections sub menu, hit add to collection. This will create a new collection called 'Collection.001'
  4. delete collection 'Collection'
  5. Cube has now disappeared from the scene.
I confirm this happens in Linux 957b4547
Unlinking the object from its last collecton shoud move it to the scene collection rather than deleting it, but this may be related to a different issue/bug.
Sebastian Parborg (zeddb) triaged this task as Confirmed, Medium priority.
This is maybe more of a design issue than a bug. Afaik it works like this because it cam from the old Groups feature.
But in any case, yes, new Collections should be added to the Scene by default I think.
I still see this happening in 2.80, edbf15d3c044, master, 2018-11-28, also like @Jose L. Carmelo (Jose) C. noted earlier, deleting the Collection from the object panel also delete the mesh, which makes no sense.
What is weird is that you can select a collection in that menu but in the Collection panel you can select an existing collection like you can in the object panel.
Adding an existing collection from the collection panel could be a useful duplicate method instead of selecting and then right click "duplicate collection"
