Crash selecting path as render as type in particle system.
Operating system: macOS Sierra
Graphics card: AMD Radeon R9 4096 MB
Broken:2.80 , 26d5a3625ed, 2018-11-29
(example: 2.79b release)
Blender crashes when selecting "Path" as "Render As" type in the particle system.
**Open Blender.
Create Particle System
Set Particle Render As type to "Path" **
Sebastian Parborg (zeddb) triaged this task as Needs Information from User priority.Jan 4 2019, 12:04 PM
I can not reproduce this issue with a build from today, could you retry with a recent build?
Tested today on same system with todays build and still have the same crash.
2.80 Beta
Date: 2019-01-04 13:30
Hash: 2c21e3e35f30
I've been experiencing the same issue, including with today's build.
OS: MacOS X El Capitan 10.11.6
Graphics Card: NVIDIA GeForce GTX 670 4095 MB
Could you guys run blender with --debug-gpu and attach the output you get when it crashes (as a file).
You can also try to run blender with --debug-gpu-force-workarounds and see if that helps.
The terminal output I got was simply:
Writing: /tmp/blender.crash.txt
Segmentation fault: 11
Interestingly though, with --debug-gpu enabled, doing anything with hair particles yielded a whole bunch of:
Warning: Pass : , Uniform 'u238133262' not found!
Warning: Pass : , Uniform 'a238133262' not found!
Warning: Pass : , Uniform 'u' not found!
Sebastian Parborg (zeddb) raised the priority of this task from Needs Information from User to Normal.Jan 5 2019, 9:22 PM
I believe macOS particle drawing crashes were fixed, if it's still an issue we can reopen the report.
