Blender 2.80 changing mode in one window is changing it everywhere #58252
6 Participants
Reference: blender/blender#58252
Operating system: Windows 7
Graphics card: GTX 1070
Broken:
2.80 Beta
Date: 2018-11-29 15:57, Hash:
26d5a3625e
, Branch: blender2.8Worked: Blender 2.79b and 2.79 daily builds
When having divided screen changing between edit and object mode in one widow is changing it also in other. Not only that but it adds overlay of edges/verts/faces which makes render mode only usable in object mode. I cant work in one window in edit mode and see rendering updated in other which was possible earlier. Being forced to see edit overlay on rendered view totally kills the purpose of rendered view...
Create any object, divide screen in 2 vertically, on right window set view to rendered, turn off all overlays, go to left side and change mode to edit. It also changes to edit on window that is set to render mode.
Added subscriber: @nezumi
Added subscribers: @WilliamReynish, @fclem, @brecht, @lichtwerk
Thx for the report,
regarding
modes
being global in the application: I think this has always been the case (also see the manual )?It was the case in 2.79 as well (but you did not see verts/edges/faces, true)
Not sure if there are plans to decouple editmode drawing from the actual mode you are in [or if this could simply turned off -- which I can see the benefit of (in rendered view)]
Maybe @fclem, @WilliamReynish or @brecht could comment?
That being said, I am not sure if this can be called a bug (it is working as intended after all), but for the presented usecase, this could be improved upon, I agree...
Since this is more of a design question, I'll leave open for now and assign @WilliamReynish, OK?
The issue is that disabling Overlays does not disable the edit mode drawing.
I'm not sure if that's intentional, but I think edit mode drawing should respect the overlay setting?
@brecht: It was always this way, but I actually agree with you. When using Eevee or Cycles in Edit Mode, it can be useful to model without seeing the edit cage. Disabling Overlays could completely disable mesh display.
Especially if you have two viewports as the reporter above is doing.
@brecht: +1
btw.: we could probably remove the
Wireframe
Overlay setting from the UI when in editmode (since its showing all edges anyways)?It is extremely useful to model something on one side of a screen and watch it updated in real time (or close to real time in case of cycles) in other window. Loved it for many years in Blender and now with Eevee it would be even more efficient. Having edit mode drawing overlay the rendering is imo defeating the purpose of rendered view. Specially when it comes to more dense meshes - render is being practically covered with wireframe display and we cant see it. Making it an option would not only brought back functionality present in 2.79 but expanded on it. Thats why I reported it as a bug - because this option was available in previous versions. Thank you for considering it!
@brecht @WilliamReynish it was this way in the begining. But I think we reverted it because in 2.79 you still display edit wires on top of solid/material view if only render is enabled. Basically the old behavior of hidding the wires in rendered mode was a limitation.
For me it make sense to hide all overlays even edit ones. But that can create confusion I think.
You decide of course but just last thing. If we have an OPTION to hide it all or leave edit lines - then we can have a choice. Not giving an option clearly is limiting whats possible. If somebody will hide all overlays - can be confused as well before he realizes whats up. 2.8 suppose to be able to do whatever was possible in 2.79, right? ;) OK, I shut up now.
@fclem, for who was hiding the wires a limitation or confusing? I can imagine some setup where you want to focus on modeling only, and enabled "Only Render" to hide all other distracting stuff? 2.8 has more overlay options like Extras for that, which might be a good replacement. But I'm just guessing here.
In any case 2.79 had the option of having a rendered viewport without any overlays, so that's important to keep supporting too.
@fclem @brecht I think one of the reasons we always show the wires, is to make it clearer that you are in Edit Mode.
But, we could make that clear in other ways. Some apps do things like having different colors in the UI chrome when you are in different modes (XSI for example). That is something we could solve separately.
In any case, it should be possible to view the scene in Edit Mode without the edit cage display
Added subscriber: @paleajed-3
Dear all,
I have nothing to blame for not including this feature, which adds possible working habits for 3D modelers, than a strange rigidity in the developers eyes, which truly I do not understand... All arguments against seem unrealistic, as we should aim on maximum expressive possibilities, instead of limiting functionality which only favours the beginning modeler, who will be delighted to later on discover these extra possibilities arereally there. I for one work on a more and more professional level, ALWAYS using multiple (up to five different) viewports using the same well-explored method, with one of the viewports in solid edit mode (with edit cage) to do the actual editing on. This allows fast working updates, using a low subd level to allow even faster updates. Rendered view just clouds the editing... It is really necessary to have the other viewports unclouded by the edit cage. Without, no real esthetic or emotional impression of the art piece can be obtained. Be very aware that this should be one of the high aims of every 3D creation suite, creating maximum awareness of exactly what one is shaping, together with expressiveness of operation. As I see it, Blender often realizes the second, but with this limitation falls short of the first.
I have now reported other bug that is kind of related: https://developer.blender.org/T60254
I really tried to use to this new idea of overlay of mesh on rendered view but this is simply killing the purpose of "rendered view". I dont see what is being rendered because mesh is covering it. And if I have an option to turn overlays OFF, but it is hiding overlays only partially (mesh is still visible) then it doesnt make sense... Not in rendered view.
I know it could be confusing if you turned off mesh in edit mode because it would look like object mode. Sure, leave it there. But rendered view should represent what will be rendered regardless of mode you are in. By far this is the most frustrating part of working with new Blender for me. I was using it all the time and it worked beautifully. So helpful! Please kindly take a second look at this limitation.
@fclem: Would you be ok with making it so the edit cage display gets hidden when overlays are turned off?
Personally I'm ok. But I would like to see a collective consensus on this matter before changing it.
Also would it be ok to have the same behavior for other edit mode for consistency? (armatures edit/pose/curves etc..)
Sure, those would also be invisible I suppose. @brecht : you also agree to make it so turning Overlays off hides the Edit cage?
Yes.
Closed as duplicate of #62774
