Nurbs circle and curve dont draw in objectmode
Operating system: Win10
Graphics card: Nvidia
Broken:
2.8 Beta
When trying to create a surface / nurbs circle or curve all you get is a single point. The surface, cylinder, sphere, and torus work as expected.
In Modelling work-space, click Add / Surface / Nurbs Circle. I am very new to Blender so possibly I am doing something wrong.
Philipp Oeser (lichtwerk) triaged this task as Confirmed, Medium priority.Nov 30 2018, 1:31 PM
Confirmed these dont draw in objectmode.
(try going into editmode and you can see that that the control points are all there)
@Clément Foucault (fclem): could you check on this?
Philipp Oeser (lichtwerk) renamed this task from Nurbs circle and curve produce nothing to Nurbs circle and curve dont draw in objectmode.Nov 30 2018, 1:41 PM
its work as always in edit mode. its not a bug
in object mode its drawing
@Sergey (koloved): have you tried Add > Surface > Nurbs Circle?
(these dont draw for me -- linux, 970m)
adding a curve works though Add > Curve > Nurbs Circle...
yeah , its works! =) gtx 1070 windows 10
I too could add a Curve > Nurbs Circle and use that for the bevel profile. I can see the Surface control points in Edit mode but there is no Circle inside the points. I also crashed Blender when I dragged one end of the bevelled bezier curve toward the other end with the intention of closing the loop.
The problem is that loose edges are not drawn in object mode, like we do for meshes.
@Stephen Hall (stephenmhall), for crashes you can report a separate bug, it's unrelated to this one.
