Print3D addon failed #58317
Closed
opened 2018-11-30 15:26:24 +01:00 by Sherm Stebbins · 9 comments
Operating system:
Graphics card:
Broken:
(example: 2.79b release)
in Print3D addon: in edit mode or not:
RuntimeError: Error Object'--temp--.006' has no mesh data to be used for casting
**System Information** Operating system: Graphics card: **Blender Version** Broken: (example: 2.79b release) (example: 2.80, edbf15d3c044, blender2.8, 2018-11-28, as found on the splash screen) Worked: (optional) ![image.png](https://archive.blender.org/developer/F5768825/image.png) **Short description of error** in Print3D addon: in edit mode or not: RuntimeError: Error Object'--temp--.006' has no mesh data to be used for casting **Exact steps for others to reproduce the error** Based on the default startup or an attached .blend file (as simple as possible).
Author
Added subscriber: @Sherm
Author
Also it duplicates the item anytime I hit check all and get the error:
Also it duplicates the item anytime I hit check all and get the error: ![image.png](https://archive.blender.org/developer/F5768866/image.png)
Member
Member
This is an issue with the Object.ray_cast api function itself and not a bug in the addon.
This is an issue with the `Object.ray_cast` api function itself and not a bug in the addon.
Added subscriber: @Dragon.Studio
I have encountered this issue when I try to check Thickness, all other checks seems to work fine with default cube.
Added subscriber: @capnm
Added subscriber: @Joefelix
Closed as duplicate of blender/blender#57861
6 Participants
Reference: blender/blender-addons#58317
