In Sculpt mode brush angle of rotation is broken
Operating system:Win 7
Graphics card: gtx 550ti
Broken: Blender 2.8 beta about an hour build
(example: 2.79b release)
Worked: (optional) Blender 2.79 latest master
  • With the default cube go to sculpt mode
  • Do ctrl+f and move the mouse the widget should show the angle you are rotating your brush.
To see the way it supposes to work, try the same instruction in Blender 2.79
Philipp Oeser (lichtwerk) triaged this task as Confirmed, Medium priority.Dec 5 2018, 1:51 PM
Seems like it is actually working behind the scenes (I am getting to correct [rotated] result on the mesh when actually sculpting strokes).
But the UI isnt updating the texture in the brush circle correctly.
rna_TextureSlot_brush_angle_update() is only called after confirming the Angle? shouldnt this be called all the time?
not sure if rB35b731c9c8bd is related (havent checked further yet)?
