UI Defaults to Unusably Translucent
Operating system: Fedora 29; Linux localhost 4.19.4-300.fc29.x86_64 #1 SMP Fri Nov 23 13:03:11 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
Graphics card: GTX 1050 Ti
Broken: 2.79 a9bd7883484 (Downloaded Dec 1st)
(example: 2.79b release)
The entire UI is translucent
  • Fresh install of Fedora 29 Workstation using Gnome 3
  • Fresh download of Blender
  • Simply open Blender
  • UI is unusably translucent
    • If light windows are behind Blender, Blender doesn't even look like it's opened at all
    • If dark windows are behind Blender, Blender UI can be seen, somewhat
I apologize if there's an easy way to tweak the UI back to normal here. If this is a default setting and not a bug, it seems highly inappropriate.
Note by the screenshot that other windows (eg: Thunar sitting behind Blender) don't have this problem.
Just thinking out loud...
I wonder if this is some bad interaction with a compositing window manager.
Cannot reproduce here (I'm on fedora 29 gnome as well, with a 970m using 410.78 drivers)
Any other applications having the same problem? Or is this only happening for blender?
Sebastian Parborg (zeddb) triaged this task as Needs Information from User priority.
I can not reproduce this either.
Philipp Oeser (lichtwerk) closed this task as Archived.Jan 9 2019, 9:50 PM
Since last asking for information it has been 7 or more days, due to the policy of our bug tracker we will have to archive the report until the requested information is given.
