b28: shift+left click doesn't select
Closed, DuplicatePublic
Operating system: Ubuntu 18.04
Graphics card: 2X GTX 1060
Broken: 2.80
Worked: (optional): 2.79
Shift+leftclick doesn't select multiple nodes in the shader editor
  • Simple cube with a material has both Principled + material output
  • left click to select one of the nodes shift + left click to select the second node, but it doesn't select both, just the last one clicked on.
I have "left click" select enabled.
Note that the same procedure works in other areas of blender, for example selecting multiple bones.
