Sliding edges and vertex Inconvenience
Closed, InvalidPublic
Operating system: Win 10 pro 64
Graphics card: Zotac GTX 750 Ti
Broken:2.80
(example: 2.80 release)
(example: 2.80, a205493426b, blender2.8, 2018-12-03, as found on the splash screen)
Sliding Edges or vertex with double tapping 'G' Key while holding down 'Alt' key, I cannot commit to changes with left moues click. I have to press Enter key in order to commit to the changes.
select an edge, double tap G key to enable sliding, hold down Alt key to enable Extend feature slide and Left Click. ( you need to press Enter key to commit to the changes.)
Jacques Lucke (JacquesLucke) lowered the priority of this task from 90 to 30.Dec 3 2018, 6:05 PM
Maybe you have "Emulate 3 Button Mouse" enabled?
Sounds like a similar to T58612.
However something should be changed here so that it is possible to commit the changes with left click.. @Brecht Van Lommel (brecht)
Bastien Montagne (mont29) changed the task status from Unknown Status to Invalid.Dec 13 2018, 11:03 PM
