Non Manifold shift+ctrl+alt+m does not work.
Operating system:
Graphics card:
Broken:
(example: 2.79b release)
I've tried several different projects and intentionally put an object with a open section :
Then I keep trying shift+ctrl+alt+m as per the 2.8 Manual. Still it won't do anything. 2.79b, no problem works great. In 2.8 I don't see an error nor does it find any Non Manifolds. Also I did open the information window and no text was produced after hitting shift+ctrl+alt+m
Thanks Sherm
Brecht Van Lommel (brecht) closed this task as Archived.
Some shortcuts were removed in 2.8, so we have some room for future features: T55666: Minimal Keymap Proposal.
You can assign a shortcut yourself if this is an important feature, in the Select > Select All By Trait menu.
The 2.8 manual is in the process of being updated, it's mostly outdated still.
