Particle Edit Crash
Closed, DuplicatePublic
Operating system: MacOS Mojave
Graphics card: Intel HD Graphics 4000/Nvidia GT 650M
2.80, 63ac7c799c8, 2018-12-02
When adding a particle system with the hair type, and change to Particle Edit mode, Blender crashes immediately.
Add Quick Fur and change mode to Particle Edit mode. Crash.
Kristian Emil (z01nk) triaged this task as Normal priority.Dec 3 2018, 10:51 PM
Kristian Emil (z01nk) raised the priority of this task from Normal to Confirmed, High.
Brecht Van Lommel (brecht) raised the priority of this task from Confirmed, High to Needs Triage by Developer.Dec 3 2018, 10:58 PM
Please leave it to developers to set the priority.
Of course, my apologies 🚀
Cannot confirm here (linux, 970m)
  • Not sure if you can force MacOS to run blender on the NVidia GPU alone? (if so, does this prevent crashing?)
  • Could you post the crash log here as a txt file?
  • see also here
  • see also here
Here the crash report from the system. I tried locking my computer do the nVidia card, by changing the Energy saving settings, like this: still crashes.
( I don't see any crash reports in my /tmp folder or at the save destination )
Looks like this was crashing in GPU_shader_transform_feedback_enable
@Clément Foucault (fclem) commited a relating fix (see rB0fe5a789837394d54c1a7570ef1e46c8ab3b0830)
@Sven Stober (Stober) , @Kristian Emil (z01nk) : could you check again with the newest build and see if the issue is fixed for you?
Hi Clément, thanks for your reply.
There's no updated MacOs build available. I will check it when the newest build is online.
Thanks to all of the developers for your amazing work on Blender!
I'll check as soon as the next build is up 👍
And as @Sven Stober (Stober) said, thank you @Clément Foucault (fclem) for committing and thank you to all the developers for your brilliant work!
@Clément Foucault (fclem) @Kristian Emil (z01nk)
Hi Clément,
just checked the latest MacOs Build from today ( blender-2.80.0-git20181211.f60018e425a-x86_64 )
Blender still crashes immediately when trying to enter particle edit for Hair.
"Also I think there is still the problem with subsurface and volumetrics in Eevee. ( T58793 )
Cheers and thanks,
Sven
Sebastian Parborg (zeddb) triaged this task as Needs Information from User priority.Jan 4 2019, 2:26 PM
Is this still an issue with a build from today?
