Control+R not work
MacOS 10.14.1
5K 27" 2017
Blender 2.79b for Macintosh. Control + R yes.
Blender 2.80 for Macintosh. Control + R doesn't happen.
Make sure use Macintosh not Windows.
Brecht Van Lommel (brecht) triaged this task as Needs Information from User priority.EditedDec 4 2018, 2:37 PM
Please provide exact steps to reproduce the problem.
It's not explained which editor or mode you are trying to use this shortcut in, or to perform which operation.
Note that Some shortcuts were intentionally removed, but for example loopcut in edit mode still works as far as I can tell.
Edit mode
Did you check your own Macintosh?
I tried it on macOS, it works fine for me.
Did you test in the exact same file in 2.79 and 2.80? Did you make any change to the preferences that affect this?
Really Command+R on Blender 2.80 it work?
2.80 did not change since from start daily build about 2 months ago still on ~/Library/Application Support/Blender/2.80 folder
Command+R doesn't work for me in either 2.79 or 2.8 (and was never part of the default keymap as far as I know).
Ctrl+R works in both here.
Yes I did test 2.79b and 2.80 is the same Command+R
I am sorry my brain confused. CTRL + R ** sorry.
Let me remove 2.80 folder is in ~/Library and I check.
Oh I see. magic mouse scroll move up very hard while slow finger move up.
Very easy scroll move down while finger slowly move down.
How can fix more easy finger slowly move up on magic mouse?
I have hard time to see too thin while CTRL+R while mouse over the edge.
The thin lines are the same issue you reported in other tasks.
The Scrolling Speed you can configure in macOS mouse system settings.
I disagree with you MacOS mouse system settings.
Blender 2.79b is perfect scroll up and down.
Blender 2.80 is hard to move up scroll.
Why you did not answer to me. Please answer me and need to fix on your Blender 2.80 within MagicMouse.
Because I haven't had time yet to test with a magic mouse. Please understand this is not a support system, I go through dozens of reports a day, you can't expect immediate answers.
Sigh make sure Macintosh with MagicMouse. I will wait.
Check both 2.79b and 2.80 you will see.
