2.8 Beta Crash with multires modifier + boolean
What I did:
  • Added cube
  • Added multi-res modifier
  • Selected simple, subdivided a few times (4)
  • Sculpted some details
  • Duplicated object
  • Sculpted details on new object
When I tried to add both cubes together (as I've done in 2.79) I went into object mode reduced the resolution for to 0 for all options (rendered, scultped, etc.) then added a Boolean modifier and chose "Union".
made sure I was in Object mode and solid surface, not Wireframe.
hit apply
instantly crashes
With further attempts, I found if I select to hide the effects of the multi-res completely (Use Modifier during render & Display modifier in viewport) it works but crashes as soon as I re-enable them.
Rocket (RocketFriday) triaged this task as Confirmed, High priority.
Rocket (RocketFriday) raised the priority of this task from Confirmed, High to Needs Triage by Developer.Dec 5 2018, 6:15 AM
Sebastian Parborg (zeddb) triaged this task as Needs Information from User priority.Dec 7 2018, 1:40 PM
Can you add a blend file so I can try this out easily? There is a lot of bug reports flooding in so it would be great if I could check this quickly
Since last asking for information it has been 7 or more days, due to the policy of our bug tracker we will have to archive the report until the requested information is given.
