deselect/select for Circle and alt+B Function doesn't work in edit mode
occasionally the deselect/select for Circle and alt+B Function doesn't work in edit mode
Alex (AlexBitsadze) updated the task description. (Show Details)
Philipp Oeser (lichtwerk) triaged this task as Needs Information from User priority.Dec 5 2018, 11:18 AM
Could you please be more specific as to which keymap you are using?
Which tool / operator is this meant for? (e.g. Circle Select?)
Also some other information missing from this form https://developer.blender.org/maniphest/task/edit/form/1/
Marking as incomplete until we have required information...
It's buggy for both ALT+B and also C (for circle) I couldn't manage to point it out in which occasions it goes buggy but just now I had selected several objects together and when I went to edit mode after some time it didn't respond to ALT + B or C select/Deselect option. when I went to object mode and back to edit mode it started working again.
Date: 2018-11-30 00:46
Hash: 4c31ed6b6
Branch: Blender 2.8
Alex (AlexBitsadze) added a comment.EditedDec 5 2018, 12:57 PM
Here is the Video. I guess its Better{F5833244}
Hash: 4c31ed6b6
Branch: Blender 2.8
Alex (AlexBitsadze) raised the priority of this task from Needs Information from User to Normal.Dec 5 2018, 1:04 PM
Philipp Oeser (lichtwerk) raised the priority of this task from Normal to Needs Triage by Developer.Dec 5 2018, 2:15 PM
Alex (AlexBitsadze) renamed this task from deselect midle button doesn't work in edit mode to deselect/select for Circle and alt+B Function doesn't work in edit mode.Dec 5 2018, 3:28 PM
Campbell Barton (campbellbarton) triaged this task as Needs Information from User priority.Dec 7 2018, 3:43 AM
Missing a blend file and steps to redo the error.
Philipp Oeser (lichtwerk) closed this task as Archived.Dec 19 2018, 1:43 PM
Since last asking for information it has been 7 or more days, due to the policy of our bug tracker we will have to archive the report until the requested information is given.
