the Unwrapping function doing wrong calculation
Open, Confirmed, LowPublic
Operating system: Windows 10
Broken: 2.79, 2.80
wrong size calculation uv shells
PS in other software
maya
rizom uv
Not sure if other software is comparable 1:1 here (I assume they all have different implementations).
For this specific file I am getting seemingly better results if you use Conformal method (rather than Angle Based) which you can change in the redo HUD after unwrap has executed.
If you do that, results are closer to what you see in other software mentionend.
To be sure, I'll add @Brecht Van Lommel (brecht) as a subscriber, but I think this is working as intended? (and could be closed?)
[not saying there isnt always room for improvement...]
Brecht Van Lommel (brecht) changed Type from Bug to To Do.
Brecht Van Lommel (brecht) triaged this task as Confirmed, Low priority.
Would be nice to investigate once, probably it's a precision issue in Angle Based Flattening. I consider this low priority though.
yes! its work! = )
but as i can see , it's so hard to see that small button for anyone who use blender, i constantly forget about it
but i know , its UI problem
Sergey (koloved) added a comment.EditedDec 5 2018, 3:37 PM
I can say only one
1)it work well on that one
  1. it's wrong on that one, when i increase the size of the mesh by Y axis
Yes, very small triangle angles are problematic for these kinds of algorithms, it's a known weakness.
