Build 94503efb126
Running the tools template ui_tool_simple.py results in the error
Traceback (most recent call last): File "/ui_tool_simple.py", line 35, in <module> File "/ui_tool_simple.py", line 28, in register AttributeError: module 'bpy.utils' has no attribute 'register_tool'
I assume the API simply changed, but I don't know what the new function is, unless tools are also supposed to be registered with register_class?
