Boolean Modifiers Don't Work Properly #58812
5 Participants
Reference: blender/blender#58812
Operating system:
Graphics card:
blender-2.80-a205493426b-win64
Certain options for the boolean modifier doesn't work how it should. The union option worked once for some reason but never again. The other options will do weird things. 99% of the time I get a messed up result or nothing happens at all when using the boolean modifier.
Use the boolean modifier on meshes. You can try and union two meshes etc.
Added subscriber: @Mr.Prick
Added subscriber: @ZedDB
I can not reproduce this issue. If I take two cubes all boolean mode seem to work fine between them.
Added subscriber: @moisessalvador
It works fine for me. Consider providing a blend file with an example of this. Also, check that the Overlap threshold in the Boolean modifier is set to 0.0 exactly, since merging vertices can give problems
Boolean Issue.blend It doesn't always happen, but in this case, the union option wouldn't work.
Sadly, that's a known limitation, sorry. Parallel faces with 0 distance on the same space don't work, and some volume needs to overla. Here is an exagerated example, but you can separate faces and overlap the volumes just a very very little ammount like this and it would still work. I heard Howard Trickey might work on improving booleans in the future :)
Added subscriber: @eoinoneill
Added subscriber: @lichtwerk
Guess this can be merged into #47108 [which is alo mentioned in #47030]
Closed as duplicate of #47108
